Vhs player wont eject the tape?
I have an older, I wanna say 9 inch Emerson T.V with a built in VHS player. The Vhs player was working fine but now all of a sudden it cant eject the vhs tape. What should I do? The model is an ECW1301
    Top Expert:
  • Televison & ... Master
  • 43,969 Answers
If your Emerson TV is an older unit, the VHS player may have worn out
Posted on Jul 10, 2013
dodgecharger
  • 254 Answers
SOURCE: SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Posted on Apr 16, 2007
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 77 Answers
SOURCE: VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Posted on Feb 26, 2008
Danmart
  • 291 Answers
SOURCE: vhs player eating tape
Hunnn....Eats the tapes, with salt & paper?..just a joke!
The tape runs on a guide ( sort of a tiny ledge )when it is fully engaged. The tape cartgage is loaded ' sucked ' in with gears that drop the cartage on top of other switches to give direction, so that "fingers" pull the tape towards the reading\recording heads. When the tape IS aligned properly, BUT is locked in the proper position the tape will NOT touch the upper or lower "ledge" that keeps it accross the heads.When the tape is NOT aligned the upper or lower tape WILL touch causeing damage. OPEN THE CARTGAGE ,Look to see if the upper & lower of the tape is damaged. Now when you say "eats the vhs tape" Does the tape comes out WRINKLE, CRINKLED,CRAMPED UP??? Then that could be ANY wheel with a black rubber rim. going bad. replace if you can. but they are VERY HARD TO FIND if u don't know what u are doing.
Posted on May 30, 2008
  • 6 Answers
SOURCE: EMERSON VHS VCR 4000 OWNERS MANUAL
www.usersmanual.com. last I knew it was free.
you're welcome!
Posted on Jan 17, 2009
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have MAG TV model CT270MW8 27 inch that wont stay on unless a VHS tape is in and then only if VHS player ejects it (automatically) and then reiserts itself. The tape then/must stay in
You have a mechanism problem in the player---it has two sensors in the tray and they detect the tape is in and load it.
If the unit was working it will each time turned on cycle the mechanism to see that it functions--shutdown if not functioning correctly.
Apr 28, 2012 | Televison & Video
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
EWV403 VHS VCR: Can't get it to eject the tape. Any suggetsions...
This is common for this player. if you need the tape, send it to the shop because parts inside can break.
May 18, 2010 | Emerson EWV403 VHS VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
