F25432 need a new remote
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
I assumes it to be an RCA ATv. If so, 1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205 check these codes. If you wish to get more, check the sites linked here. http://electrohelponline.blogspot.com/
http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Posted on Jul 11, 2013
F25432 need to find out where to get a remote RCA
By precious solution, I've pointed out the setup codes to RCA TV with RCA RCR311W model remote control. I repeats. 1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205. For more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Televison & Video
I have a gold gemstar/rca 36inch tv and I can't
to enter the codes u must use yhe orig. remote
May 22, 2010 | RCA F25432 25" TV
Is there a focus control on the back?
you have to remove the back panel to see the fbt there shoud be a focus control there
May 04, 2010 | RCA F25432 25" TV
Tuner connection broke
set tuner cap re solder with tuner fix this problum solve esyly but don,t fix it your self if your not tv.techician.becous it is a dengerus for you.
tv. tuner is not costly.
Nov 16, 2009 | RCA F25432 25" TV
REMOTE DOES NOT WORK ON SYLVANIA TV
It sounds more like a problem with the TV, than the remotes. It's possible that the IR reciever or microprocessor for it have pooped out. It's something that would have to be serviced by a shop, but due to the age and size it would likely be cheaper to replace the whole TV.
Dec 04, 2007 | RCA F25432 25" TV
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Sep 29, 2007 | RCA F25432 25" TV
TV WILL NOT COME ON - TV Chirps when you plug it in
The F25432 uses the CTC203 series chassis. The most common cause of the picture being intermittent is poor solder joints on the small coil connected to the base of the horizontal output transistor. These cracked solder joints will eventually cause the horizontal output transistor to short, and the power supply will "squeel" when plugged in. If you have experience working on TV's then you can try resoldering the joints on that coil and checking/replacing the horizontal output transistor. If you do not have experience working on TV's then allow a qualified tech to handle it for you.
Aug 21, 2007 | RCA F25432 25" TV
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
RCA Model number F25432
the horizontal output transistor my be shorted out, or the flyback transformer my be open? Have you unsoldered and tested? If you are not a technician, or have no experience I would not suggest to work on the tv yourself. good luck, Mike
Nov 27, 2006 | RCA F25432 25" TV
RCA Mdoel number F25432
Is that an L4401? Your missing a number if thats an RCA part number. You did not state if the sound was also gone out. This coil does not go bad, but needs to be unsoldered, then the leads need to be scraped off and then reinstalled and resoldered. This will make the set go on and off all the time. Not just turn off the picture. This coil is located on the printed circuit board, and connects the secondary of the horizontal driver transformer secondary to the base of the horizontal output transistor. Also if the set trys to start up three times and stops, the flyback is bad and is no longer available. if you have no tV repair experience, play it safe and seek out a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Nov 26, 2006 | RCA F25432 25" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
