Question about Cardo Scala Rider Teamset Pro
Headsets wont pair up
Units have worked fine for about 18 months but now will not pair up when switched on. try'd to pair with mobile phone. 1 would not so swithced off and try'd the other unit, that one paired up instantly, any ideas please
How to put peltor bluetooth into pairing mode
Normally Peltor headsets work as follows:
1.) Turn the device off.
2.) Once off, hold the on/off/mode button for 5 seconds until you hear a voice say "pairing mode"
3.) Make sure bluetooth is active on your device and search for the Peltor headset, once you find it select it.
4.) When prompted for a pairing key use 0000
that is 4 zeros.
5.) Headset should say pairing complete.
As with moth bluetooth devices remember this muse bt done within a normal amount of time so have your device ready to search by time you put headset in pairing mode will help.
Dec 22, 2012 | Peltor MT53H7BWS2 Bluetooth Headset
Lost pairing?
the headset might be broken (the speaker)
try to connect to another mobile phone and check if it works, then report back
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
No audio
not sure about the bluetooth settings on an Iphone sounds like the speaker may be broken. have you tried pairing it with another phone if it works on another phone its probly just settings
Dec 02, 2011 | Samsung Wep470 Bluetooth Headset
Not in english? I bought the ProMedia Stereo Bluetooth Headset product in the Netherlands, and need the manual in English.
I can translate the whole instructions but most functions speak for themself.
The only problem I think you are facing is how to connect to a mobile phone, computer or tablet.
This is colled paring (pairen in Dutch) see page 7.
A short translation of this page in English.
Turn the headset on. (page 3, pt 4)
For pairing hold the multifunctional switch (page 3, pt 1) for about 10 seconds. the light (page 3, pt 2) will blink from red to blue and repeats this in a continues mode. Now the headset is in paring mode. You can now find it in your mobile phone list.
If your phone is asking for a code then type four times a 0.
If you are out of reach the headset will connect again on it's own only when in reach within 2 minutes.
After switching off then on the headset will try to pair with the latest paired phone/ computer.
I am using the same headset with upgraded speakers. Works fine with a Ipod Toch and mobile phone.
Good luck.
Jul 10, 2011 | Radio Communications
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Good luck from Headsets Direct!
Feb 14, 2009 | Plantronics Explorer 330 Headset
Trouble after installing firmware
I had the same problem before I even upgraded the firmware, it showed up after I selected "delete all" in the paired devices menu. I upgraded my firmware to try to the problem but it didn't help but I did come up with a fix thats worked twice for me. so heres the fix i use  1. delete the pairing on your mobile phone.  2. switch on the headset then hold the on switch in the pairing position for about 7 sec. which should put it in pairing mode.  3. do a search with your mobile phone for a new device and it should show your headset 4. pair with it like normal
after pairing my headset's display always comes back on and then operates like normal  hope that helps
Jan 25, 2008 | Jabra BT8010 Wireless Headset
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
H350 pairing with Blackjack
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Sep 14, 2007 | Motorola Mobility H350 Wireless Headset
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Cardo Scala Rider Teamset Pro Logo
Top Cardo Radio Communications Experts
vimal
vimal
richie46
Tom Chichester
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
