Question about Troy Bilt 5.5hp Self Propelled Mower
The blade belts keep coming off - Troy Bilt 5.5hp Self Propelled Mower
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Troy Master
  • 1,917 Answers
Check for ether bent pulley or split pulleybent or twisted deck or broken lawn mower frame around one of the welds or bad spindle bearing
Posted on Jun 07, 2014
My deck belt keeps comeing off my mower ltx 1040
be sure the pulleys isn't bent. there should be belt guards. be sure they are on. with the engine off see if you can turn the blades to see when and where it is coming off.
Apr 26, 2017 | Cub Cadet Garden
The drive belt keep coming off. New mower had another one the same problem took it back and exchanged it for this one 42in mustang
If your drive belt comes off, it's usually a sign of either the belt isn't right, too long... OR the belt guides are either missing or installed incorrectly. There should be guides next to each pulley which keeps the belt close so that when the blades are disengaged and loose, they won't flip off once activated
Nov 05, 2015 | Mustang Garden
Deck belt engages but wont stay on
Make sure the belt keepers around the blade spindle pulleys are in place they are designed to keep the belts from coming off the pulley adjust to about 1/8-1/4 inches from the pulley...also make sure the belt tensioner is tight on the drive belt when engaged if it isn't your belts probably need renewed..good luck...
Jun 24, 2015 | Garden
What would make a mower blade belt come off the pulley? My mower is a LX 176 38inch cut
Check if a stick or ecp. Check your spring, still hooked.
Oct 16, 2014 | Garden
Toro groundmaster 325d wont turn off and belt keeps coming off
The won't shut off has to be a faulty ignition switch. The belts coming off indicate a problem the belt pulleys.The bearings may be bad and freezing up, this will cause the belt to smoke and tear up as well as make the pulley wobble . Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release on front and side of deck. While the blades are disengaged turn all the blade hubs and pulleys to see if the turn fairly easy. Check for play or wobble in the pulleys and blade hubs(bearings and blade shaft, also known as the"spindle assembly") attach to these pulleys. Also check the idler pulley(also called the tensioner pulley for wear and check to see that they are in alignment with each other).
Apr 28, 2014 | Toro Garden
The blade belt keeps coming off
check belt length for stretch.pulleys for wear,oil on belts &or wear of belt.check engage handle adjustment is correct
Jul 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Blade belt ariens lawn tractor
I would check to make sure none of the pulleys are bent or has any kind of dents or dings around the rim of them and there is a belt arm that is suppose to keep the belt from jumping off and sometimes its out of position and will eat the belt up
Apr 05, 2013 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
I have a troy bilt pony and the drive belt to engage to blades keeps coming off. I have replaced the belt and the pully what else could it be?
well i would take a long look at the spring which holds the tension pulley in place. if it is weak, or not connected correctly, there will be inadequate tension and the belt can come off. I would also take a look at whatever fasteners keep the deck in place as if it is not kept to the rear, there again will be too much play in the deck belt.
Apr 05, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
