Question about Dryers
Minka aire uc9040t
I have a UC9040T SWITCH and it is not working i ordered a replacement switch and they sent me a WCS212 can this work
2 Suggested Answers
SOURCE: We have a UC9040T switch
I have minka aire uc9040t wall controller. If there is no green light make sure you have power to the controller wall switch. Mine had power but no green light, remove and disconnect the controller, open it up, remove the back plastic cover, you will possibly need to replace the internal 5 amp fuse that is soldered in. It is labeled on the bottom of the circuit board, and is encased in rubber heat shrink tubing. You will need soldering tools and skill. Mine was blown, replaced - works now.
Posted on Sep 02, 2012
My minka wire light does not work is it the dimmer switch on the fixture
Check for 120Vac cming into the light fixture, if its there, the problem is your fixture, the fixture switch, or the way you wired it into the circuit.at the light fixture
Aug 17, 2014 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
We have a UC9040T switch that stopped working after our power went out. Any suggestions?
Sep 10, 2011 | Minka Aire Ceiling Fan
I have a minkaie switch model uc9040t, I went to turn the light on, on the fan and it blew the light and now when I look at the switch on th on position the green light is off like there is not electricity...
I have a minkaie switch model uc9040t, I look at the switch on the on position the green light is off like there is not electricity coming to the switch, but itested the cables and there is electricity, and of course the fan won't turn on either, is there a way to reset this switch
Jan 31, 2011 | Minka Aire Ceiling Fan
Minka Aire Fan will not reverse.
My fan is a concept II and it had the same behavior. I called Minka Aire support about this - they said it was either the reverse module or the receiver. They sent me both no charge! I replaced them and now my fan reverses. i am not an electrician, but the replacement was fairly easy. Just made sure to disconnect 1 wire at a time, connect it to the new wire, etc until I was done. Minka Aire support said they would walk me through it on the phone but I didn't need them to.
Sep 30, 2009 | Minka -Aire Brushed Nickel Remote Control...
We have a Milano Model No. F527 fan. The light comes on spontaneously at random times and the fan can only be turned on and off sometimes. Other times it works perfectly. The remote control batteries are...
Get in touch with Minka group Mr. Minka who will assist. I'm working on my same problem right now. You need to reset the dip switch in your remote or wall switch and also the same setting on the fan.
Jun 29, 2009 | Minka Aire Ceiling Fan
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
