Dayton blower motor schematic for a model 4m098J
2 Suggested Answers
  • 252 Answers
SOURCE: looking for a Dayton Shaded pole blower,modle 2C646, 1500RPM
Dayton is a private brand which belongs to WWGrainger. Other brands should have a sutable replacement or take it to a motor shop for repair/replacement
Posted on Aug 23, 2009
Dayton furnace / blower won't turn on
Test the blower motor relay and see if it is working.
Dec 16, 2016 | Dayton Heating & Cooling
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
I just bought a dayton model 4m098j direct drive motor i hooked up white wire and the black it hums when it turns it is realy slow i dont have any thing for the two brown wires to hook to can you help me...
The brown wires go tto the capacitor...
Here is the page
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=4m098&op=search&Ntt=4m098&N=0&sst=subset
On the top right of the page you will se that the cap. is a REQUIRED accessory....buy it and hook it to the brown wires and the motor will run...
heatman101
Feb 24, 2011 | Dayton Permanent Split Capacitor Motor Fan
I have a dayton blower, model no. 2C647A mounted on a Hitzer hard coal stove. The electric motor is very hot to the touch after it has been running for 1/2 hour plus or minus. Is this normal?
Yes, They get hot-actually they can get so hot that they will burn you..I had 6 of these to keep foliage nursery roofs pumped up-- To make them run slightly cooler i restricted the air input opening to the squirrel cage-- It worked pretty good
Oct 29, 2010 | Dayton Shaded Pole Blower 134CFM 1500RPM...
My Dayton 3E382D heater will not light because the plenum is missing. Where can I buy a plenum and where can I view a schematic for this unit?
For a schematic go to Dayton Furnaces on the internet and type in your model # and you should be able to download a parts diagram. The plenum you can buy at your local hardware store.
Oct 15, 2010 | Dayton Gas Furnace Heater
Have a Dayton Model 3e228D heater. Problem, unit fires up but fan does not come on.
The fan switch on this unit is a bi-metal switch located on the heat exchanger. Check for a bad connection. It is 120 volts so be careful when checking. you can test the switch with an volt meter or one of those probe lights to see if the switch closes when hot. you are looking for 120 volts to the blower motor. Spin the blower motor to see if that is bound up with debris.
Dec 01, 2009 | Dayton Heating & Cooling
Low rpm on blower motor
The 1350 RPM Speed is for 50HZ. The motor will only run at 1525 on 60 HZ.
Nov 30, 2009 | Dayton Shaded Pole Blower 480CFM. 2 Speed,...
How to wire a 1dgv1 speed control to a 1tdu8
You will wire this just like a single pole light switch, take your power from your panel (black) to one of the pigtails or set screws and then take another black wire leaving the speed controler to your blower motor. Take the common/white wire directly to the blower, polarity sould not matter which leads you connect them to in the blower.
Oct 09, 2009 | Dayton Dryers
Looking for a Dayton Shaded pole blower,modle 2C646, 1500RPM
Aug 21, 2009 | Heating & Cooling
Heating & Cooling Logo
151 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
