Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
My minka concept ll remote fan and light keeps shutting off after a period of time,quite frequently. What do I do to correct
Shuts off on its own,by itself
    Genius:
  • Minka Master
  • 1,617 Answers
Try changing the frequency in the receiver & transmitter.
Posted on Jul 12, 2013
  • 13 Answers
SOURCE: 2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Posted on Apr 23, 2010
mcdevito75
  • 1970 Answers
SOURCE: My minka aire concept 2 ciling fan worked but now
mcdevito75 here, Sounds like the fan motor is seizeing.
Posted on Jul 27, 2010
  • 377 Answers
SOURCE: 3 concept II fans
According to the URL at: http://minkagroup.net/Admin/UploadFiles/F518-English.pdf there are dip switches on the fan. They are on the receiver that is most likely tucked away in the bell housing at the ceiling level. Pull the bell housing down and you will find a box of sorts that has the switches on it. This is the receiver.
If this solution is helpful to you, I would appreciate a Thumbs Up rating. Thank you, Paul
Posted on Oct 14, 2010
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
alpug
  • 1961 Answers
SOURCE: Minka Aire Concept II Wet fan with remote control.
the electronic board of your fan must be check.there are triac transistors that switch the motor to it variable speed check the triac and replace it if you find it faulty.there 3 triac found on it these rae the switches of 3 speeds you can compare the resistance reading of all of the 3 triacs to determine which triac is faulty...good luck.
Posted on May 31, 2011
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Can I use an incandescent bulb in a MInka Aire Concept II with light & remote? What is the highest wattage I can use?
Take the bulb to a bulb store & show it to them. They should be able to find a different bulb you can use.
Feb 26, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
I have a Minka Aire Concept 1 which has been programmed to operate from a different frequency than nearby fans with remotes. The light goes on and off by itself at will and goes off each and every tim
Does your neighbor have a remote fan? Check wattage of bulbs to make sure they're the correct wattage. Still not working correctly, call 1-800-307-3267 (Minka Aire)
Sep 20, 2014 | Minka Aire Ceiling Fan
Light ON Fan ON. Cannot operately sperately by remote.
Do you have a Fanaway or Minka Aire Concept fan? Anyway it's usually wired this way; Black to black, white to white & red to blue.
Apr 14, 2014 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
Minka aire concept 1
Might need a new receiver.Call Minka @ 1-800-307-3267
Jun 10, 2013 | Dryers
No light or fan minka concept ii ceiling fan
You need a new receiver or tyr resitting the one you have and see if that works.
Mar 24, 2013 | Minka Concept II Flush 44 Ceiling Fan by...
I have a Minka Aire ceiling fan. It is two years old. It has a remote. The fan will not stop! We took off the blades to stop the air (it is dead winter here) but the whole light just spins and wobbles. Not...
One simple thing to check is to make sure the DIP switches in the remote and the receiver match up. There should be a set of small switches (usually inside the battery cover) that are set for a sequence. The sequence on the receiver must be the same. Otherwise, you probably have a bad remote or receiver.
Feb 26, 2010 | Minka Concept II Flush 44 Ceiling Fan by...
2 remotes
Jun 24, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
165 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
