Question about Samsung Refrigerators
Replace main control board refrigerator
What is main control board of Samsung refrigerator get function for?
  • Samsung Master
  • 16,166 Answers
What is the make and model number?
Posted on Jul 10, 2013
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
farfield
  • 462 Answers
SOURCE: Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Posted on Apr 17, 2009
  • 56 Answers
SOURCE: Replaced control board Kitchenaid KBFA25erss refrigerator
should be on the serial plate
Posted on Jul 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
  • 32 Answers
SOURCE: I have a Samsung RB195BSSB Refrigerator with
YOU MIGHT HAVE A GAS LEAK THAT CAN CAUSE THE PROBLEM. I WOULD SUGGEST THAT YOU GET A TECHNITION TO CHECK IT OUT FOR YOU.
Posted on Sep 07, 2009
Samsung rs265tdbp refrigerator is iced up and freezer works fine. is it the defrost heater or defrost control?
Hello Marc-Ryan Digesu,
You have given this some thought... Very impressive!!
It can be only three things (barring physical wiring damage):
YES... Highly likely it is the CONTROL BOARD
Looking into your model (but you MUST verify the DA41 00670 NUMBER yourself)...
(3 basic parts of your DEFROST CIRCUIT)
- heater(s)... very unlikely
- defrost thermostat... unlikely
- clock/timer or control board... most likely (easiest)
The first thing you want to do (after removing power)
BUT before REMOVING ANYTHING...
take LOTS of USEABLE pictures. You will need to put every wire & screw exactly back EXACTLY from where it came!!
Always ground your hands before touching any circuit board you VALUE (BETTER purchase an anti-static wrist band... below).
Look at the bottom of the board for any obvious solder issues...
Else.. order that spare board you always wanted (anyway).
Always get three estimates... (about $115)
Prices may vary but the parts are ALL THE SAME.
Hope this helps... I like refrigerators... feel free to comment me back if want to discuss...
(I have a spare board & door gaskets... because I plan on KEEPING my refrigerator (until that HOT PLACE freezes)).
Even on eBay
Samsung DA41 00670C Assy PCB Main Main Control Board for RS265TDWP XAA OEM
Also at appliancepartspros:
http://www.appliancepartspros.com/samsung-assy-pcb-main-da41-00670c-ap4700476.html
Sears
Refrigerator Electronic
Control Board Part Number DA41 00670C SAME DAY...
partsselect.com
PartSelect Appliance Parts and Repair Help
Jun 01, 2016 | Samsung Refrigerators
Do main control boards have a manufactured date on them?
The manufacturer does have date codes built-in to the boards, but there is no information on how to decifer it. The problem is that old boards do have to be returned for dud charges. Sorry, but I'm sure this is not what you wanted to hear. Any other reason you wanted to check?
May 14, 2014 | Samsung RS2630SH Side by Side Refrigerator
I need to locate and replace a main board on a Samsung RS 67 LASH
Hi, Usual positions are either on the top or behing the panel at the rear of unit on RH side if your facing the back..
Dec 13, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
Samsung rs261mdpn
Replacing the main control doesn't fix anything on the display they have separate functions. You need the bom number to find the display board it should end in /xaa or something like that
Nov 06, 2013 | Refrigerators
Ice forming on bottom of freezer compartment Samsung RF4287HARS.
dont worry about it, you probably didnt get the freezer drawer closed all the way. frost will form when it doesnt get closed properly. just make sure it is closed now and the unit will clear the frost in a few days thru normal defrosting cycles. be sure that the drawer is closing on all sides by looking at the gasket and all should be ok in the future.
Nov 02, 2013 | Samsung RF4287HARS French Door...
My samsung RS263td is not even a year old. it stopped working. the indications on the temp for the freezer and refrigerator are rolling.
Chances are the electronic control board module are not functioning well. A electronic component is defective. It's replacement is the whole control board not the part by part replacement. A moist develop inside the control board will likely to cause that trouble also. So control board it must be check.
Thanks for asking.
Jul 04, 2011 | Samsung RS263TD Side by Side Refrigerator
Fridge will not adjust temp, set @ 37* will go to low of 29* what part is needed?
you will need to access and replace the "A.S.M. main control board" in the rear lower corner of the back of the unit,as this board controls all refrigerator functions,it has a cover over it, un plug refrigerator,unplug the board after removing protective cover, then reverse procedure and plug in board and re-plug in refrigerator and this will take care of the temperature problem you have
Dec 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2534WW
Hello Mike , The main control board is on the right side in the back of the unit. look for where the power cord goes iunto the unit after you remove the cover on the back. there should be a large white plastic box on the right side. that is the main control board.
Dec 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
