Emachines et1831-07 shuts down mid boot
I have a emachines et1831-07 and its shutting down about 3 or 4 seconds into the boot process. I was told it was the power supply. So I bought a 550 watt rocketfish power supply and its still doing it. Any suggestions?
    Brigadier General:
  • 3,400 Answers
Http://pcsupport.about.com/od/findbysymptom/ht/pconthenoff.htm
find you this to read it stands much to use.
Posted on Jul 10, 2013
Testimonial: "Thank you so much you saved my computers life I figured out that it was the power switch that shorted out."
  • 749 Answers
SOURCE: COMPUTER POWERS DOWN AFTER 3-4 MINUTES
In addition to that, check also the heatsink on the processor if it needs dusting, it may be filled with dust that it doesn't allow air to pass through to cool off the processor.
Please keep us posted.
Posted on Nov 27, 2007
SOURCE: power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Posted on Jan 24, 2008
  • 50 Answers
SOURCE: emachines shuts down by itself all the time
There are a lot of problems with Emachines as far as motherboards go. Since you've already replaced the power supply, it's safe to say that it's not causing your issue.
Since you seem comfortable with the inside of your machine, go ahead and take out all unnecessary components. If you've left your machine the way it was since you've bought it, start with the modem card that's in the bottom PCI slot. Often, those can cause issues with the computer not starting up, staying on, etc.
Also ensure that the machine is free of dust, and that all cables and connections are secure. Try not to let things float freely, and make sure you're plugging the machine into a surge protector, and not directly into the wall.
Posted on Apr 09, 2008
sentsignal7
  • 186 Answers
SOURCE: I have an emachine T2984
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
Posted on Jan 17, 2009
guitarmanjoe
  • 336 Answers
SOURCE: come on, boots up, then shuts down 5 - 10 minutes later.
I recommend checking your power settings in the control panel, it should actually be under display settings. It may under those settings somehow be set to shutdown in 10 minutes. You can find the power settings, sleep mode, UPS, and hibernation under the "screensaver" settings of display. Look for a tab on the screensaver settings that says"power settings".
Posted on Mar 19, 2013
The TV shuts down after a few seconds
You will need more serious diagnosis than can be given here. A TV is like a computer, It has a "Boot-up' process and when it fails to 'Boot-up' properly, it shuts down.
Mar 08, 2015 | Mitsubishi WD65731
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
Shutdown problems
I assume it is not shutting down. Do a complete reset, unplug computer from wall push power button in for 3-5 seconds, then plug it in and restart the machine. Then let it complete the boot up process then go to start and shut it down again see if it shuts down now. Thanks for the question hope this assists you. John
Jan 21, 2011 | Gateway DX482203 (PTGA002009) PC Desktop
Emachine 725 keyboard does not and machine hangs up
Re-boot and see if it happens again. To shut it down, press and hold the power button till it shuts off. Remove the battery and power adapter and then hold down the power button for about 10 seconds. Then re-install the battery and adapter. Push the power button to energize the laptop.
Nov 04, 2010 | Acer Computers & Internet
Computer won't begin boot process and shuts down in seconds...won't give time to try to boot from recovery disk
This could be a power supply problem, first to assertane what the problem is you will need to take the side panel off, make a note of where the cables go before touching anything, remove any ribon cables from the motherboard and any other peripherals attached to the computer ie printer, scanner,etc, you only need the keyboard and mouse attached at this point, reboot the mechine. post back what happens and i will run you through the next step.
Oct 27, 2010 | E-Machines eMachines Desktop PC
I put in the recovery desk. I pushede F11 as prompted. I then pushed "R" for recovery and the computer shuts back down before recovery.
Some model of emachine will cycle through the recovery process. When your pc shuts down after pushing R, is it immediatly or does the pc perform a bit longer and then shut down? Also, when it shut down, do you push any buttons? (you should not have to.)
Thanks
C2Solutions
Jan 24, 2010 | E-Machines eMachines Desktop PC
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Added memory causes machine to shut down and boot up continually.
it proves that your emacchine does not support your addition of memory try a bit lower capacity memory
Aug 22, 2009 | Computers & Internet
Quickrestore- keeps shutting down mid-process
Sounds like the cd/dvd is not reading the cd's correctly, Not sure if my compaq restore cd will help but here is the link to cd 1
Download the file burn ISO to cd and boot from cd,
For giggles did you try an external cdrom?
Mar 29, 2008 | HP Compaq Presario 2100 Laptop
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
