Question about Garden
Why engine shuts down when engaging pto on troybuilt RTZ50
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
To low govenor speed need to raise it do this be fore you shear the key in the motor if this keeps that will happen
Posted on Jun 07, 2014
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
wadembly
  • 475 Answers
SOURCE: pto engages but the tractor shuts off
check the safty swith under seat if its bad it won't allow you to turn pto on for deck run a jumper wire in the plug if it works while you know its the safty switch
Posted on Jun 05, 2009
  • 85 Answers
SOURCE: Cub Cadet LT1018. When I go into reverse the
the safety switch on the pto lever is not activated (lever is not back all the way)
this unit should not cut in reverse
Posted on Aug 17, 2009
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
HansPP
  • 2510 Answers
SOURCE: Engine dies when PTO is
It sounds like you may have a siezed bearing or something jammed in the PTO mechanism. In any case, you will have to strip the PTO to troubleshoot it. A complete PTO replacement will probably not be called for, just the defective part.
Posted on Jun 09, 2011
Engine runs, but when I engage the electric PTO why does it go dead?
Newer mowers have a safety interlock that prevents the mower running when going in reverse. My guess is that the reverse switch is on and when the PTO is activated the engine dies like you shut off the key.
Second idea is that the device the PTO drives is frozen up. Test this by trying to see if it turns with the engine off. When you engage the PTO the engine chokes down because it can't turn the PTO.
Mar 29, 2016 | Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Shut down problem
im betting the center pto is still engaged still , this is a safety system (no start with pto engaged) I come across once in a while , not many folks use the center pto so it gets forgotten till somehow the engage lever gets set there , or sometimes it sticks in too
that's the simple thing I can think of , it only gets more deep from there
Jun 24, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Troybuilt Mustang RZT mower pto blades not engaging
Unplug the wire at the pto and turn the ignition key in the on position, us a tester to see if you have 12 volts to this plug, if you do then the pto itself is bad, if not then the pto switch is most likely the culprit.
Jul 29, 2014 | Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Why wont my pto engage?
is there power going to the clutch?
May 18, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Aug 19, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
