Question about Rowenta DG5030 Iron
Won't stop steaming - Rowenta DG5030 Iron
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
No steam coming out of iron russell hobbs precision heat digit model14773
i know mine won't steam either unless you have the dial set to steam. not sure if your has the same set up but i thought it might help to offer the information
Jul 16, 2012 | Irons
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
No steam from a grime buster steam cleaner what is wrong?
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity.
Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size.
Good luck.
Jul 07, 2011 | Irons
My clothes steamer won't keep putting out steam stops after about 5 min
It sounds like it is shutting off on high temperature because of a line/scale obstruction. You may need to descale it. Use CLR (available from home improvement stores or supermarkets) or something similar. That should get it back in operation.
Jun 26, 2011 | Yamata PSS-2001 Iron
Rowenta DG5030 Iron Logo
29 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
