I need torque settings for a Hyundai Atos 1.1 gls cant find anything on the net
SOURCE: my hyundai atos (r reg) cuts out under rapid acceleration only
hi
thanks for making contact.problem solved via another totaly free site and better inspection on my part.
SOURCE: where is the oxygen sensor located on the hyundai
follow the exhaust pipe from the motor. i beleive it is before the catylitic converter. screws into the side of the pipe and there are wires attached to it.
Robert
SOURCE: High rev when starting hyundai atos
Check the vacuum hoses, but sounds like the IAC or even the o2 sensors. The computer will pick up on the o2 sensors but not the IAC..Go to your local ADVANCE store and they will check on computer for free :)
SOURCE: clunking sound from front wheels, suspension on Hyundai Atos
It sounds like the CV joints are due to be replaced. Make sure you get them replaced and do not drive it too far, because the CV joints will fail anytime now. Once the CV joints fail, your going to have to get the car towed to get it fixed. Good luck and keep me posted, Oh and don't buy the car from there, who knows what else is wrong with the car that they are hiding from you.
SOURCE: Hyundai Atos GLS 4 door hatchback won't start/turn
If you have not found the problem yet, check the transmission interlock. Sounds like the shifter interlock switch may not be engaging to allow the starter to activate!
