Can't turn disc protection off
    Genius:
  • 1,054 Answers
What brand/model?
Posted on Jul 10, 2013
code for lg bh7520tw does not work as I don't have a set up button on remote
Jul 10, 2013 | Panasonic DMR-E55 DVD Recorder
I can't open my password protected disc. I know the password but there is no option asking for the password
what options are available if you right click on this iomega drive
also if you select properties after right clicking on it and select properties what options are available ?
Oct 01, 2012 | Iomega ZIP 250 External ZIP Drive
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
How do I remove write protection from a DVD-RW?
Your M35X-S1143 model - assuming it still has the stock drive - has an DVD / CD-RW optical drive - i.e. it will write only to CD's but not DVD's. If you try to burn a DVD, it'll tell you that the disc is write protected (when in fact, the drive doesn't even know how to write to a DVD disc.); if you go ahead and burn a CD, you will not encounter the write protection warnings.
Aug 31, 2011 | Toshiba Satellite M35X-S1143: M35X-S1143...
Can't play CDs in my car. The Unit gives me error code 4
The error 4 in most CD Player is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
"Error 4" is a mechanical disc loading problem. The disc probably hasn't been seating in the #6 carrier properly, leading to some mechanical interference when it is selected. It would seem to be properly seated now, but next time you have it out you might check it on a perfectly smooth flat surface to be sure it is not warped slightly. Try another disc in that position, one you know to be trouble-free.
I burn a lot of discs for my clients and have never had a problem with the mid or high-grade discs from Taiyo Yuden, and others. Even lesser discs like Ritek perform fairly well. Some brands - usually the no-names - fail right out of the box. One of the problems seems to be that the cheapest discs are pretty thin and subject to mechanical problems like warping.
If you use "economy" discs particularly, be sure to put a label on them. Most of the cheap discs don't have much of a protective coat on top and scratching the top metal foil finish can lead to serious playback troubles as the disc is read by the laser from the bottom.. In addition to telling you what's ON the disc, the label helps protect that critical foil.
Hope helps.
Aug 20, 2011 | Car Audio & Video
The display says, "insert disc",
Thank you for posting to Fixya.com and it is my pleasure to guide you.
1. The disc may be turned over. Insert the disc with the playback side facing down.
2. The disc may be dirty. Wipe it with the correct type rag.
Since you stated the display is showing then I take it the player is on and the chord is plugged in.
3. Is the disc completely centered in the tray? I have done that before.
4. Have you run the self-diagnosis function? If the Error code 'AACS ERR' shows then it is an "AACS read failure". Remove the protected disc. Then turn the unit off and wait a minute or two and back on.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 18, 2011 | Sony BDP-S300 Blu-Ray Disc Player
HOW TO unprotect JVC 3 DISC RADIO??
You don't UNprotect it, you solve the problem. Protection is hard-wired.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
May 29, 2011 | Audio Players & Recorders
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I keep getting ''windows unable to complete format"whe i try to format a floppy disc
Hi Shollmanjr,
Have you check if the write protection switch is "turned on" on the floppy disc? (it's in the back of the floppy disc, check it out. It's probably write protected).
Dec 07, 2010 | Computers & Internet
I have briught a panasonic dvd-ram like it say's in the manual to record tv programs when i am out and it comes up disc protection on go to page 11 in manual to turn off and i cant figue it out please help...
Easy fix
On your remote press "Functions"
A menu will appear on your screen. Use the up / down keys on your remote to select "Disc Management" You should see a tab marked "Disc Protection" Use the up / down keys on your remote again to select this tab. You should now be able to turn the protection off. When you gave finished, press Enter and then Return on your remote.
Please note, the Disc Protection function is used when you have made a recording and you do not want to record over it or erase it by mistake.
Hope this helps
Jul 07, 2010 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
