Question about KitchenAid KCM111OB
Put the machine through the Clean cycle and after it was finish the machine turned off and will not turn back on. How do I get the machine to re-set and work again?
What do I put in the machine for the tub clean cycle?
john low temperatures washing can cause the machine to smell
if it was me i would set the machine to it's hottest wash and use a descaller or bleach and washing liquid ,after wash has finished give it an extra rince cycle./ scrum around rubber seal behind door before starting wash. check pump filter is clean,
Sep 22, 2016 | LG WM1814CW Front Load Washer
Checking to see if the water line is clogged or broken on my cuisinart dcc1200 coffee maker. The water doesn't come out of the showerhead. Help!!
Most likely clogged with a calcium buildup. Run a solution of water and vinegar through the machine to dissolve the hardness buildup. Stop about 1/2 the way through and let it set for an hour. Turn back on and let it finish. Remember to run a pot of clean water through after to wash out the vinegar. (You may have to run more than one clean cycle if it's really clogged).
Aug 31, 2016 | Cuisinart Coffee Makers & Espresso...
Run cycle is almost three hours on my 6 or 7 year old machine and it's not always cleaning very well. Any suggestions?
First try cleaning out the machine with a gallon of vinegar run through the wash cycle several times. Turn off the water. If you have a manual dial set machine, try to set your machine to come on, at the longest cycle, then add the gallon of vinegar. Stop it before it drains out and reset it to the longest wash cycle again. After the third time you try this, turn the water back on and let it finish the cycle. Alternatively, use a product called Lemi-shine to wash the tub and wash arms out. It may take 2 packages. In the future add 1/4 cup of vinegar to the wash cycle to keep it clean. Secondly, check the float and make sure it is not coated with gunk. Remove it and scrub it out with a strong detergent and hot water. Check to make sure the drain is not blocked in the bottom. To do this, remove the lower tray and put it aside. Then remove the flat plate looking cover ( check ofr a knob that might be screwed down to keep it in place, and remove that.Sometims they screw in reverse.) and look for hidden objects that might be blocking the drain. You can use an old toothbrush to scrub into the corners and around the drain screen to get out the gunk. Then replace everything and give it a run.
Mar 04, 2015 | Bosch Dishwashers
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hello.. I have a Zanussi Electrolux essential 1200 6kg machine. My problem is that during the wash (usually about 40 mins into it) the machine seems to think the cycle has finished and cuts out before...
Something could be stuck in the pump , drain the machine down drain hose next to drain plug when all water is out put a towel under drain plug unscrew then look in the drain plug and your see a little propeller, make sure it turns and nothing stuck there to stop it turning and leave clean then try again good luck
Dec 13, 2017 | Zanussi FC1200W Front Load Washer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
KitchenAid KCM111OB Logo
48 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
