How to operate bush 6 head nicam hi-fi videoplus vhs
Cannot get a picture - sound only. How do I record a VHS tape onto a DVD
    Brigadier General:
  • 3,400 Answers
READ YOUR MANUAL CAREFULY.
Posted on Jul 10, 2013
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 4234 Answers
SOURCE: no picture on vhs tapes
Is the picturejust snow or no picture at all? Most cleaning tapes won't work if the heads have been clogged up because of a bad tape. A professional cleaning and alignment may be in order here. Can you clarify the lack of picture please?
Thanks,
Dan
Posted on Nov 14, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
RFICKES
  • 51 Answers
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Posted on Jan 04, 2009
  • 21 Answers
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Posted on Jan 27, 2009
Anyone know if a Signalex Universal Remote has a code for a Bush Head Nicam Hi-Fi DVD/VCR Combo? Or how to put videos onto disc using the DVD/VCR? thanks
http://resources.jvc.com/Resources/00/00/97/LPT0719-001A.pdf Even though this manual says JVC, when I found this bush head manual, this is what comes up, so I think the information will apply to your recorder.
May 13, 2017 | Bush Televison & Video
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
While playing vhs tape, the sound is great, but the picture comes and goes.
That's usually dirty or worn out heads or not enough take up tension in the tape
Sep 27, 2014 | Toshiba RD-XV49DT DVD/DivX/VHS...
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I have copied a personal wedding DVD onto a VHS
I contacted Panasonic direct by phone & they were extremly helpful.
Many thanks ,
Your's, J W Firth
Jan 12, 2010 | Panasonic Televison & Video
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Sony SLV-N750 sound problem
befor i give u answer of this Q.i m gona ask u some think to make sure u regulur tape is orignal recoding from company is not that means u recrder vcr out of alighnment on audio head ..so chack that ....and hi fi system very sensetive about it,s audio head alighment ....or might u notice movie runs slow some time or fast ......if that kind problem u can't do much about it only u can do use the orignal record tape or alighment a audio head ...good luk...oh yaa clean head first ..
Dec 21, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
