Question about Amana Refrigerators
Freezer not cold enough fridge fine
My Amana side-by-side, model number arse67rbc, is not freezing. I took the panel inside the freezer off and the coils had a huge chunk of ice. I melted that and left the panel off for a day to watch it. The coils would get a little bit of ice on them and then defrost, which I think is the way it is supposed to work. However, after filling it with ice packs and some tubs of ice (to help it cool faster), everything is still melting. Any ideas? Do I need to replace the run capacitor? Thanks!!
  • Amana Master
  • 16,037 Answers
The issue is the defrost timer.
Posted on Jul 10, 2013
  • Jennifer Jul 11, 2013
    I don't think it is the defrost timer since the coils were freezing up and then thawing for a day or two while I had the inside panel off. I could also hear water dripping and "sizzling" during the defrost cycle. I also don't know where the defrost timer is. I've looked everywhere and don't see it. Is it possible that this model doesn't have one and it is controlled by the motherboard?
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My kenmore refrigerator side by side
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Oct 17, 2007 | Refrigerators
Not getting cold
fan only comes on when evaporator is down to temp. the fact it is not coming on points to a compressor fault ie evap not getting cold enough
Jun 10, 2007 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
89 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
