Question about Ademco Computers & Internet
Alarm siren Siren only chirps, otherwise does not work.
blueextc3221
  • 15935 Answers
SOURCE: Car alarm not working
Usually, the siren is mounted in the engine compartment along the firewall pointing downward to drain any water accumulation.
It will have red & black wires connected to it, and (if done professionally) black wire loom over the wires to protect them from heat and debris under the hood.
Posted on Jan 14, 2009
SaintGene
  • 53 Answers
SOURCE: hi lo alarm siren when playing online games
Hi stretcharm_2,
It seems that the hi-lo siren from the mobo indicates that the cpu is over hated.
1st of all, you need to go into the BIOS/CMOS setup to check if the temperature was boosting higher that the prefix alarm. If it's low, but gone up very fast after a few minutes, you need to update to the latest BIOS firmware, as it's part of the Fatal1ty problem.
you can download the bios here, be sure to read all the instruction before you proceed to update the BIOS firmware.
http://www.abit.com.tw/page/en/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=motherboard&pTITLE_ON_SCREEN=Fatal1ty+FP-IN9+SLI&pSOCKET_TYPE=LGA775
PLEASE BE EXTRA CAREFUL WHEN UPGRADING THE BIOS AS IT MIGHT KILLED YOUR MOBO.
you can always come back here and post a comment if you r no sure.
2nd of all, you need to check is the heatsink was fixed properly.
It's not your fault that's the fan wasn't fixed properly because the stock LGA-775 socket T heatsink's design wasn't a perfect one, and it has 4 very fragile fix-in clips. You need to check if all four clips were fixed firmly in the braket for maximum heat dicipation. It might be broken and you need to replace with another one.
You might need to replace the thermal paste to a better 1.
Please check your manual on how to diassemble the heatsink.
Good Luck,
Don't forget to rate my solution, thanks!!
Posted on Jan 17, 2009
  • 22 Answers
SOURCE: no sound coming out of siren from alarm. hooked
put a 12 vt test light on your 12vt output to see if the alarm is outputing,some alarms have to be programmed for positive output as some are negative output ie;set up to hook up to horns.Also double check your earth.
Posted on Apr 21, 2009
  • 1596 Answers
SOURCE: car alarm siren won't work but still can locked and unlocked the
REPLACE SIRIEN
Posted on Jul 12, 2009
SOURCE: when i scan mycomputer then it keep siren continuously
Also, on the ic7 g, the tiny fan on the northbridge chip can fail and cause the same symptoms. (Happened to me and I spent a bit of time re-applying thermal grease btwn CPU and heatsink only to find the siren still went off under stress. The tiny fan was an easy fix. )
Posted on Jul 28, 2009
How to program remote for viper 650xv?
You can find a copy of the manual at the link below or try this:
  1. Open driver's door - leave it open (door trigger must be connected on the alarm).
  2. Turn ignition key on.
  3. Within 5 seconds, press the valet/programming button once and release.
  4. Press valet/programming button again and hold it down.
  5. With valet/programming button held down, you should hear the siren chirp within a few seconds. After the chirp, press the lock button on your new remote.
  6. After pressing the remote's lock button, you should hear a short blast from the siren. Now release the valet/programming button.
Viper 650XV Installation Manual
May 13, 2014 | Basic Remote Vehicle Alarm System
On a DEI 514N siren, what do the 2 small wires connect to?
They are for configuring the siren for louder soft chirp or one tone siren.
Dec 28, 2013 | Dei Directed Viper Python 514n Soft Chirp...
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
Mar 19, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.
If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.
Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
Mar 04, 2013 | 350 HV ESP Security System 350HV ESP
Only one of my my k-9 mundial keyless work the other seems fine but wont activate.
Try to reprogram the remotes to the alarm. Have your vehicle key and both remotes ready. The way to do this is as follows:
1. Turn ignition key to run position.
2. Within ten seconds push the valet button 5 times.
3. The siren will give a chirp, indicating that you are in programming mode.
4. Press the large button on the first remote. A chirp will be given as confirmation.
5. Press the large button on the second remote. A chirp will be given as confirmation.
6. Turn off ignition and remove key. Alarm will give long chirp indicating exiting program.
7. Try remotes. Both should be working.
For the next 48 hours, every time the vehicle is starting the siren will chirp indicating that remotes have been programmed. After 48 hours this feature will turn itself off. Also keep an eye on the alarm light as it will also blink the number of times as remotes are programmed every time the ignition is turn on.
Hope this information helps. Please rate. Thank you.
Mar 04, 2010 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Ademco 4160-12 was installed in my house in 1987.While exterior painting, the external siren wire is cut. Please help me find new siren and procedure to alarm system. This has at present only local ( siren...
any 12 volt siren will work. you my have to replace the fuse. 12volt sirens are available at radioshack, frys electronics and all over the web,
mj
Aug 06, 2009 | Ademco CIA Modem
Black widows 293 just chirps makes noise and hasnt stopped even when i reset alarm
Check two things firstly reposition the earth for the siren or /and the alarm, also is there any chance the siren got wet?
Apr 22, 2009 | Vehicle Parts & Accessories
How to turn up volume on siren. 791XV
I dont think you can turn it up. But I added 2 more sirens. The original is very small and quiet.
Apr 12, 2009 | 791XV The 791XV is a 2-way Security and...
When I use car siren, ZR4 is chirping
This is caused by electrical noise within your car's electrical system. Jump over to radardetector.net for suggestions about how to resolve this issue.
Dec 04, 2008 | ZR4 Radar Detector
Computers & Internet Logo
24 people viewed this question
Top Ademco Computers & Internet Experts
David Payne
David Payne
Are you an Ademco Computer and Internet Expert? Answer questions, earn points and help others
