Question about NEC Computers & Internet
Mini laptop manual
If i press the power button, it lights, fun makes some noise but does not show anything on the screen
  • 369 Answers
Disconnect the power cord and battery. Hold down the power button for a minute and then connect only power cord.
If not fixed, Reseat RAM, hard drive. Else, contact local hardware tech.
Posted on Jul 11, 2013
sandrew
  • 2961 Answers
SOURCE: Mouse locking/turning off laptop
On your laptops power management settings, you will probably find an advanced tab. In there you should be able to assign the power button to 'Shutdown', as it is probably 'Hibernate' enabled. The mouse problem is probably your laptops touch pad driver, update drivers from Hewlett Packard site if there are any.
Posted on Oct 24, 2006
  • 263 Answers
SOURCE: Hp Laptop problem
conect a external monitor to see if there is any image or if it is the same maybe the memory or prosesor damage
Posted on Dec 30, 2007
asish_shrm
  • 121 Answers
SOURCE: My mouse buttons on laptop are very loose
It looks like you have broken plastic grove that holds the button to place...and this is giving you the clicking sound...
if you don't to use an external mouse....you will need to take it to repair center ...if you think you are capable of opening the top cover of you notebook without problem....let me know...
Cheers
Posted on Nov 14, 2008
SOURCE: blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Posted on Jan 02, 2009
pagebor
  • 2785 Answers
SOURCE: Toshiba A300 not booting.
plz take out the battery and try if the problem is not solved then try by resiting the ram. if you are not familiar with the computer terms and parts you plz ask some professional to help you from your area
Posted on Feb 22, 2009
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
Computer stops after 3 seconds from start
try takeing the battery and power lead out and holding the power button pressed for about a minute then plug it back in ,if there no joy then theres no easy solution to your problem without testing parts inside ,if under warrenty return it for repair or replacement ,could possably be motherboard
Mar 11, 2010 | Acer Aspire 5315 Notebook
Ok My Acer mini laptop, keeps getting this
Heres what you do....
* you need usb disk drive
* a second computer with internet access (can be work cafe friends place)
* a file you can download from acer or search yourself called ZGIA32.zip
Format your drive in fat (*note i tried fat as directed in a number of manuals though then tried fat32 and it worked then though suggest you try fat first *shrug)
open zip file and copy 3309.fd and the fla.exe to the usb stick
rename 3309.fd to ZGIA32.fd
Turn off your laptop making sure that both battery and power supply is plugged in and attach the usb stik/drive.
hold down FN and ESC keys and press the power button, continue to fold FN and ESC keys for 7-10 secs then release - at this point the power light should be blinking and you should still have the black screen of death.
press the power button once while its blinking - this will initiate a bios update * DO NOT PUSH ANYTHING AFTER THIS
After 2 mins the aspire should reboot itself , wait for about 7mins if it dosent before rebooting manually
Oct 17, 2009 | HP Pavilion ze4300 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
When i press the power button it makes noise and the screen does not show anything
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
Aug 15, 2009 | Acer TravelMate 2355 Notebook
Mini Acer Aspire One
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 13, 2009 | Acer Aspire One PC Notebook
It will not come on. It shows in the mini screen
sir i want to download free soun driver for compaq c500 lapop
Apr 11, 2009 | Compaq Presario PCCOM2232US Notebook
Feb 22, 2009 | Toshiba Satellite A300-0CF035 Notebook
SCREEN NOT WORKING
If the screen is blank then you probably switched to an external screen,to switch to a tv
No worries
what you need to do is press the function key and the key with the picture of a mini screen / oval and circle
it will pull you back to your main screen: back to normal.
hope it helps
Dec 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
23 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
