Question about Jensen JTA460 Turntable
Blown speaker One of the speakers on my jensen isn't working anymore which is causing all of my records to play a lot higher that usual. The music is only coming out of one speaker and when i plug it in, the broken one buzzes and thumps. How do i fix it?
  • Jensen Master
  • 5,193 Answers
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
Posted on Jul 15, 2013
Speaker buzzes but it plays no music
Blown speaker driver. Buy a new speaker of the same frame size and ohms (Omega character symbol) usually 4, 8 or 16 ohms. Contact the manufacturer if its an expensive name brand. Check the manufacturer's literature to determine the Ohms, it will be listed. You have turned up the speaker too loud and fried the magnet. Buy better speakers rated in watts RMS... the higher the number, the better.
Aug 27, 2012 | Bose Audio Players & Recorders
Hi. Greetings. I have one of this set. One day while i'm playing songs on it, my siblings accidentally plugged another wire into the earphone port. When i unplugged it, there isn't anymore sound...
Put a plug in the earphone port and wiggle it . Could be the little gadget inside is stuck. I had a tv that did that and ended up disconnecting the ear plug port.
Sep 21, 2017 | Altec Lansing VS4121 Computer Speakers
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
I was playing then all the sudden it sounded like it shorted out. The power is still on and the tubes fire up but the "STANDBUY" switch isn't lighting up when in on position. Please help.
The speaker is blown. Did it smell a little funny when this happened. Sometimes they get a faint burning smell when they blow. Some Peavey amps especially older ones are known for letting DC current slip through to the speaker and blows it immediately. Most of the rest of the amp deals with that pretty well so I'm not quite sure what going on with the standby switch. Probably just a blown bulb.
Jul 16, 2011 | Peavey 6505+ 112 Combo Amp Combo
Pioneer VSX-21 Elite: Issue: after playing music softly for about 1 minute the machine goes into "overload" mode. Unplugging will reset this. Keeps going into this overload mode, acts like...
Check to see if the unit is getting unusually hot.
If it is, check the impedance of the speakers and speaker wires to make sure they aren't shorted, or close to shorted (ie - partially blown speaker).
Try running the unit with the speakers detatched to see if it still happens.
If the unit gets hot with no speakers and goes into overload, then we need to start checking the components inside.
Look for electrolytic capacitors that are bulged at the top, or that have discolored the circuit board at their base (leaking).
Any caps doing this will need to be replaced, and will likely solve the issue.
If there aren't any, or if that doesn't solve the issue, start checking the transistors at the output.
Look to see if there is a DC voltage riding on them, and make sure they aren't shorted out.
If the power amp is a hybrid chip, see if you can find one cheap and replace it if you can't see anything else wrong, or if one of the hybrids is overheating a lot.
Jul 13, 2011 | Pioneer VSX-21 Receiver
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
Crackling sound in speaker
These speakers have a history of being blown if played too loud. Apparently the higher quality CX version are reliable. If the lows are what is crackling, the voice coils are probably cooked causing it to drag the pole pieces.
Apr 28, 2011 | M-Audio Studiophile BX5A Deluxe
Jensen vm9413 no audio ouput
i thought my banswer went through but i guess not so i'll do so again.Often a defective speaker can cause this problem.So before you decide to replace the unit or repair it,when this happens again disconnect one speaker at a time and see if it doesn't come back on after connecting a specific speaker and goes off if you reconnect it.If it does you've found your problem.But sometimes a speaker doesn't melfunction until put under a strain.So you can also check by seeing if it shuts down at higher volumes and plays longer at low volumes which will tell you also that it is an external not internal propblem.Let me know what happens after the speaker test
Oct 11, 2009 | Jensen Car Audio & Video
Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Sep 11, 2009 | Audio Players & Recorders
Jensen JTA460 Turntable Logo
109 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
