Question about Garden
917 276813 doesn't engage gears (all) 6 speed
  • bob10082008 Jul 10, 2013
    Bottom of shift lever doesn't seem to be connected to anything. Does a spring or lever connect to the shift lever bottom?
bwery3
  • 137 Answers
SOURCE: 96 cadillac deville won't move
Either the linkage is disconnected or the transmission is bad.
Posted on May 23, 2011
kevin_getz
  • 1031 Answers
SOURCE: volvo s90 cruise control doesn't run at a constant speed
You may have a failing Cruise Control Servo. Have the servo tested by a Volvo or other qualified service center.
Posted on Apr 22, 2012
little_shaws
  • 493 Answers
SOURCE: Hi I have Honda Odyssey 2000 v.6 3.0lt, recently the transmission plays up, it doesn't shift gear, but engaged in third gear all the time and D green light keeps flashing. I don't know why it
Possibly the Throttle position sensor (TPS) This controls a number of things one of wich is when the transmition changes gear. I recomend you have the vehicle scaned though & that should give you an answer.
Posted on Jun 21, 2012
emissionwiz
  • 77499 Answers
SOURCE: Heater / air conditioner fan control doesn't engage fan. Previously, it only worked in high speed.
I would replace the blower motor resistor first then see if that corrects this. The resistor is located next to the blower motor under the dash.
Posted on Jul 16, 2012
  • 32 Answers
SOURCE: My Honda 2.4 doesn't move when engage a gear, D light is blinking, only moves slightly sometimes. What is the problem?
check shift cable on trans &check fluid
Posted on Aug 18, 2012
Manual transmission reverse is blocked
Hi Mitch, If when engaging first gear you have a grinding and clunk try pumping the clutch pedal before engaging reverse. My reason for saying that is that if the pedal takes low to the floor you may have a defective hydrolic clutch line. If it doesn't work I think I would suspect a bent selector rod. Regards John
Jun 24, 2012 | 1990 Chevrolet K1500
Jun 21, 2012 | Honda Odyssey Cars & Trucks
Tiller shuts off when I engage tines. I have changed the oil, cleaned the fuel tank out, checked the plug, I just need to know what adjustments, if any that I need to make.
Is the gear box full of oil? If it is dry it will bog down the engine and stall it. Will the engine run at full speed without the tines engaged? If it doesn't maybe the full throttle mixture screw needs adjusted out CCW a little.
Oct 19, 2011 | Garden
05 grand cherokee wont start .full power lights dont dim when cranking then it starts like nothings wrong. i tried jump starting it then i climbed under it and hit the starter and it started
If the starter motor spins at high speed, but doesn't turn the engine until you whack it, the starter gear is not engaging the flywheel. Probably the engagement fork or the starter gear is worn out or sticky, or the solenoid isn't pushing it far enough.
Sep 21, 2011 | 2005 Jeep Grand Cherokee
I have a 1995 Buick Century 6 cyl. The transmission shifts smoothly and into 4th gear but when I get to about 55 mph it shifts back into 3rd gear by itself and won't go back into 4th gear. What is...
Fourth gear in your vehicle doesn't exist. What feels like a fourth gear is the torque converter locking up. The lockup lockup is controlled by a solenoid in the side pan of the transmission, and the solenoid is controlled by the ECM (electronic control module) in response to several pressure, temperature and speed sensors etc. To determine which component is the problem you'll need a professional transmission mechanic with the proper diagnostic equipment.
Jun 28, 2011 | 1995 Buick Century
04 ram 1500 2wd. trans shudder at cruising speeds under 55? Doesn't during acceleration. Change filter and fluid to no avail.
That sounds like a torque converter problem more than likely. It sounds like it's trying to lock up (supposed to do that above 60mph) at a low speed. It will feel like a harsh shift or a shudder when it's trying to engage. Just to make sure I'm correct, drive it and listen to all the gears. When at 55-60mph after it has gone into it's top gear it will normally drop about 200-300rpm when the torque converter locks up.
Jun 07, 2011 | 2004 Dodge Ram 1500
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
