Question about Sharp Royal Alpha 9155SC Cash Register
Scanner trouble after a recent power failure, we had to reset the cash register; everything is working but the scanner. The red light comes on and it beeps after scanning, but nothing shows up on the register screen. help please!
  • avollme1 Jul 10, 2013
    I mean a product bar code scanner, not a document scanner
  • Sharp Master
  • 1,646 Answers
It sounds like you have lost the port settings. Most registers have to have the scanner port (socket) set in programming so the register knows which device you are using. I haven't worked with this model but if you need a manual, one of the users has a Royal 9155SC manual here:
http://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-9155sc_instruction_programming_manual.html
Posted on Jul 18, 2013
2 Suggested Answers
SOURCE: my sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Posted on Aug 24, 2010
Product code scanner (royal 9155SC cash register) not working
You might need to re-enter bar codes. Power failure might have deleted them
Jul 10, 2013 | Computers & Internet
System frozen
Try pressing clear (CL) then type some numbers and see if they appear on the screen. If not, you probably have keyboard failure. If they work, press clear again and try pressing 1 then CLK# button.
If anyone has trouble programming a Sharp XE-A402 cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A402_operation_manual.html
Aug 27, 2012 | Sharp XE-A402 Electronic Cash Register
My metrologic orbit scanner ms7120 wont register with cash resgiter
I think you've answered your own question. Spilling water on any electrical equipment will inevitable cause failures. It requires a repair, which we can do for you.
If you require an help on this scanner please dont hesitate to contact us
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 09, 2012 | Microsoft Metrologic MS7120 ORBIT Barcode...
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Aug 11, 2010 | Royal PS700-USB Handheld Barcode Scanner
I had posted this problem once before hopefully get assisted this time. I purchased a casio TE-4500F register with scanner I had to reinitialise it to clear old data, and reset it now the scanner red light...
Hi. This is normal. Unless you made a backup, you will have lost a lot of system programming. Firstly you must make sure you have initialised it with the code for scanning and not check tracking. To do this:
Turn key to program mode 5 SUBTOTAL SUBTOTAL
This will print the memory allocation. Next to file 16, you should see a figure in the thousands (usually 6000).
Next you need to allocate the I/O port for the scanner. Try this:
Turn key to program mode 3 SUBTOTAL 298 SUBTOTAL 2000 CASH SUBTOTAL
Now perform a flag clear to set the new I/O:
Turn key to PROGRAM mode. Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL.
Turn back to REG mode and try it. You might have to log a clerk back on after the flag clear. See how you get on.
Dec 29, 2009 | Casio Parts Cash Register PC Desktop
Casio TE-4500F cash register scaning problem
There are several things you will need to do. In the I/O program you must tell it where and how the scanner is set up and then you will have to program the scanner itself. I know this will solve it. I need to know the make and model of scanner
Cash register scanner
Here is a link for the Cash Register and tells how to program it.
I suspect the you plugged the unit in after the cash register was under power.
unplug the register and reinitialize it with the scanner plugged in so it will actually see it.
Then try using it again
http://www.sharpusa.com/files/cas_man_XEA505.pdf
If this post helps you please leave a vote at fixya
May 24, 2009 | Casio Parts Cash Register PC Desktop
Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
Mar 27, 2009 | Metrologic Instruments MS9540 Voyager...
No green ready light
There are two different type of port usually experience this particular problem.
1) If you use the scanner to com1 computer port
2) If you use the scanner to com1 cash register
The only way to settle the situation is to use the manual barcode scanner default settings.
1) Setting up default for com1 scanner
2) Setting up default for com1 cash register.
If you barcode still experience the problem you need to contact the manufacturer on that model or the reseller where you bought the said device.
Probably, the device being situated in critical effects that your scanner would not able to determine where it will send the data from your barcode scanner.
Please rate me solved if you like my suggestions.
Best regards,
Philip
Nov 13, 2007 | Opticon LGE1105RHHS-000 Handheld
Sharp Royal Alpha 9155SC Cash Register Logo
145 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
