Question about Microwave Ovens
Manual for photo frame dpf070a - Microwave Ovens
Frigidaire model PLMV178HC control panel replacement
I can't find if there's a difference between model PLMV178HC and PLMV178HCA. Every search for PLMV178HC redirects me to PLMV178HCA. Unless there is grease or moisture on the control circuit board, then you have a shorting membrane keypad.
It is repaired by replacing the control panel frame assembly, which comes with a new membrane keypad already attached.
For model PLMV178HCA, that is part number 5304470533 and you can get it from Sears online for $89.95 (subject to change).
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes. (Also, the service manual is here.)
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Be very careful when disconnecting the cables & wires. Some connectors have a locking tab (see photo) Next remove the keypad strip (see photo) Then simply move your circuit board into the new frame.
Be careful, because your display tube is made of glass, and if it breaks, the board must be replaced as well.
Let me know by e-mail if I can help further.
Regards,
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Jul 17, 2014 | Frigidaire Microwave Ovens
How to change a membrane switch on a samsung microwave model number smh9151s
This is actually a simple DIY job. The service manual is at my site here.
You simply move your circuit board into a new control panel frame assembly, which comes with a new keypad already attached.
For model SMH9151S, it is part number DE94-01806K ("Assy Control PANEL") and you can order it from the Pros here for about $42.
If it is not in stock when you order, they can have it to you in just a few days.
You can also find helpful exploded view diagrams and order other parts via that link.
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes. If you have trouble, slide the hood vent grille to the left about 1/4", then then pull it forward. Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame. Be careful, since the display is made of glass.
fetch.cgi?redirect=http%3a%2f%2f031d26d.namesecurehost.com%2fmwd%2fkeypad_connector.jpg
Some connectors on the relays have a lock:
Jan 04, 2014 | Microwave Ovens
F3 and beeping on my GE spacemaker 1800 microwave oven...what causes this?
F3 is the code for a failed membrane keypad.
On most of these GE models, the keypad is not available as a separate part.
So you'd have to order so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Nov 27, 2011 | GE Microwave Ovens
My GE Microwave Oven keeps beeping and displays "F3". Model #: JNM1851DM2BB What Can I do?
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB07X11020 and you can order it for $105.61 from the Pros here.
It's not currently in stock, but they can have it in a few days. They're our favorite supplier.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 31, 2010 | GE Microwave Ovens
My GE Microwave Oven, installed 2 years stopped working, and Displayed "F3". Model #: JNM1851DM2BB How can I solve this problem? Thanks
Some connectors on the relays have a lock. See that image here:
Dec 31, 2010 | General Electric Microwave Oven
Model No. MH7130XEQ-2 Keypad does not work. Screen shows "F-2"
F2 on MH7130XEQ2 model means you have a failed membrane keypad.
This is a simple do it yourself job.
You can order part number 4359477 the control panel frame assembly here, which comes with a new keypad already mounted on it.
You simply move your circuit board into the new frame.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Aug 22, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
How do i remove the broken door handle to replace with the new one? Do I remove the frame on the inside of the door to reveal the screws to remove the inner frame to reveal the screws for the door?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We may have the service manual for download. Feel free to e-mail us at prototech@usa.net.
May 28, 2010 | LG Microwave Ovens
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
from the door frame.
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Goldstar microwave need to change the door frame help!
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 15, 2009 | Goldstar Microwave Ovens
Sharp Carousel Microwave R-1601
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 01, 2007 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
186 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
