Question about Garden
I just bought an old Simplicity and would like to know the year and get a manual
Serial number: 51826 MFG number: 1692774 Motor: Kohler Command 15.0 OHV, serial number 2707604914
  • 83 Answers
SOURCE: NO FIRE ON KOHLER 12.5 OHV MOTOR
All wires on a small engine except for the spark plug wire are to ground out the spark and stop the engine. Except a few for accessories and on generator/welders.
Knowing that, there is a small main wire that comes from your coil and leads to all other wires. It usually sits under your gas tank and runs toward your on/off switch or ignition switch. To see if it is any off your shutdowns gone bad, disconnect this wire. If still no spark then you either have a open in this wire or your magnito (coil) is bad.
If it starts, then unplug all the wires going to the kill wire and hook them up one by one until you find the one that kills the engine. Follow the wire to it's source looking for breaks in the line. If no breaks then the switch is out of place or bad.
Note: check your oil level first. Most engines come with a low oil sensor that will kill the spark if the oil level gets too low.
To check is your magnito is bad or you have a short, disconnect the wire at the magnito found by the flywheel under the flywheel cover. Tuck this wire out of the way and try to start your unit. No spark then you have a bad magnito.
Posted on Apr 03, 2009
SOURCE: i have a craftman 42"riding mower,about
Do you have a switch to engage the blades or a lever..... 1st thing check to see if the blade it's jammed on something under the deck
Posted on May 08, 2009
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
rwvanlue
  • 486 Answers
SOURCE: can't find a manual 4 my simplicity regent, 16
http://www.simplicitymfg.com/manuals/
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 28, 2009
  • 38 Answers
SOURCE: My simplicity Coronet Hydro 13 lawn tractor loses
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
Posted on Jun 04, 2010
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
What year my a/c unit was made. goodman?
Mfg date is first 2 numbers of the serial number found in the placard on the unit.
Aug 23, 2014 | Goodman Heating & Cooling
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
I bought a 2008 Simplicity Riding mower that has no manual. I'm trying to find where I can get one. I found a web sight but you have to have a model number and and I don't know where to find it on the...
the sticker with the model and serial number on my simplicity is riveted to the outside of the frame, just behind the right front wheel.
May 03, 2011 | Garden
I bought a house with aqua glass whirlpool tub (14 yrs old). Motor won't come on and I can't find reset button or serial number. Where are these items?
will have to remove access panel or make one the motor /pump assembly is mounted to the tub test for power to the switch and pump the numbers u are looking for are their by pump
May 03, 2010 | Kohler 1209-LA-0 Hourglass Whirlpool with...
I need to know the year my fridge was made
the serial number is the answer,, 9005--- it was manufactures in the 5th mont of 1990 so its 20yrs old
Feb 09, 2010 | Refrigerators
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
