Question about Campbell Hausfeld Elec pressurewasher 1600psi
Elect. motor dosnt turn off when i release triger
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
High pressure cut out switch is faulty or not enough pressure to activate switch . more likely the first.
it migh be a simple micro switch . inside a platic housing on the end of the pump inside cover.
Posted on Apr 01, 2014
Jigsaw blade release wont click when. Turned to unlock blade
Hi. Check the power outlet first.If the power is good.Check the triger switch if good.check also the motor carbon brash if good or not.The carbon brash is not good if you see that is very short and not connecting to the motor widings.
Jul 01, 2011 | Garden
The motor bouges when u pull the triger
check the carb needles ajustments may be off usually the high side is turn all the way in and turn out 1 whole turn and low side should be 3/4 turn out
Nov 23, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
The electic fan is not turning on when it should
Did you run a hot wire direct to the motor itself? Connect it direct from the batteries positive end to the motor. If it does not work replace the motor
Jul 03, 2010 | 1987 Chevrolet Corvette
I just aquired a manual for a Ryobi C356 Type III metal cutting chop saw. I've converted it to PDF format, and wondering if it would be of use to this forum?
I have a Rybi chop saw c356 it looks like the blade keeps turning lot longer after I have released the triger botton ,haw can I fix this .
Oct 17, 2009 | Ryobi Saws
Stalls when triger released
the problem may be the oil. if the oil is fine then try crimping your hose to let less water pressure through. if that still does not work lowes or home depot will fix the problem cheap. thank you for using fixya
May 01, 2009 | Garden
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Campbell Hausfeld Elec pressurewasher 1600psi Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
