Question about VCRs
Magnavox VCR/DVD combo
Can't find manual. Need help to record VCR
The Wolf
  • 10 Answers
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
Posted on Dec 10, 2007
  • 579 Answers
SOURCE: sharp dv-rw260h vcr/dvd combi
The tape drive and head cylinder motors are having trouble synchronizing close enough to allow the manual tracking to work. Does it work on prerecorded tapes?
Could be:
Too much drag from the tensioning gizmo. (fixable)
Dirty tape path (fixable)
Damaged tape (does it have a crease along one edge?
dragging motor (not usually fixable)
Hope Ya Fix It!
Posted on Jan 18, 2008
  • 864 Answers
SOURCE: Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: Need remote codes for LG RC897T.
I need codes for vc-aa350 is locked
Posted on Sep 02, 2009
  • 4518 Answers
SOURCE: Bush dvd recorder and vcr instruction manual
Try the Bush website some makers provide them free as a PDF. Otherwise post the model number on here and someone might have your model.
Posted on Mar 24, 2010
  • 7 Answers
SOURCE: I need a manual for
The link that I have provided below will take you to the manual you are looking for.
If you cannot see this manual, download Adobe Reader from this link, and you should be able to read it.
Posted on Jul 29, 2011
0 characters
1 Points
My Panasonic dvd/vcr displays hello, what is this and next?
It's simply a welcome message while the recorder boots up. 'Hello' is a common greeting in English. Your DVD/VCR is being polite.
Oct 08, 2013 | Panasonic DMR-EZ37VS DVD-Recorder/VCR...
What tuner for dvd/vcr combo JVC DRMV80B?
First you must connect the antena cable on JVC dvd/vcr ant in and from ant out of jvc connect to TV ant in. Then you must find TV programs on JVC.After that you can record a program and watch another. Be careful you record the program which you find on your JVC.
Mar 11, 2010 | VCRs
Bought a new VCR/DVD combo. Have TV with cable
Hard to believe you do not have any "F" connectors on the VCR/DVD. What brand is this? You should have inputs and outputs for separate composite and audio. Using phono cords with male ends you should be able to go to and from your television for recording and watching. It will mean alot of changing to go from one mode to the other but should be doable provided your tv has composite in/out. Your owners manual should show a diagram to hook the unit up this way. If you get stuck email me and I'll try to walk you through it. Give me as much info as you can on inputs and outputs. Let me know.
Feb 01, 2010 | VCRs
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba VCRs
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips VCRs
VCRs Logo
42 people viewed this question
Top VCRs Experts
alexander woolfolk
alexander woolfolk
Are you a VCR Expert? Answer questions, earn points and help others
