Question about Video Game Consoles & Games
Where can i get socketing rods - Video Game Consoles & Games
    New Friend:
  • 77 Answers
Try a computer/eletronics store.
Posted on Jul 12, 2013
Safari rear door latch broken
It could be that the rod has come detached from the latch mechanism itself. I had this problem on my 94 Safari. I had to remove the panel for the hatch portion (I have the dutch doors) and release the door manually (Terrible design not having an easily accessed internal release!). Once you have the door open, you can reconnect the rod into the original socket. I recommend using some safety wire through some existing holes to pull the rod tightly into the socket, but not so tight that the rod will not move. another option is to use a clip like this one that fits around the rod and linkpoint. Either of these will keep the rod firmly in place.
May 05, 2014 | 1993 GMC Safari
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
How are the tie rod ends connected to the rack unit at the opposite end of the tie rod from the wheel ? The Tie rod is free to turn. Is this normal ??
The inner tie rod is threaded onto the rack. There is a tool called an inner tie rod end tool, than will help make it a lot easier to remove. The tool can be found at any good parts store or tool store. The shaft of the inner tie rod will spin. It has a ball that is pressed into a socket. The socket is the part that has the threads onto the rack.
The way you tell if they are back is by grabbing the tire at the 3 and 6 position and pushing/pulling. If you feel any movement than look carefully at the inner tie rod and the outer tie rod to see which one is letting the wheel move.
Sep 27, 2010 | Oldsmobile Silhouette Cars & Trucks
WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
Jul 15, 2010 | General Electric GE SmartWater Household...
Need to know the size of the socket needed to remove the front hubs on a dodge ram 3500 1 ton 4 x 4 with cummins engine?
Removing Tie Rod End Attaching Nut Nut is to be removed from tie rod end using the following procedure, hold tie rod end stud with a 11/32 socket while loosening and removing nut with wrench Removing Tie Rod End Attaching Nut
Remove the tie rod end from steering knuckle arm, using Remover, Special Tool MB-991113 Tie Rod End Removal From Steering Knuckle .
Remove the upper ball joint stud from the steering knuckle using Puller, Special Tool, C3894-A Ball Joint Stud .----------------------- The procedure is :-- Do NOT pound on the outside of the hub. First you will need a 5 inch long half inch drive socket extension. Start the 4 hub bolts about half way, then witha helper hold the extension between one of the 4 bolts and the axle housing then have the helper turn the steering wheel to push on the bolt and hub. If it is really rusted in you might have to start the truck to get more pressure on it while turning. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 11, 2010 | 1997 Pontiac Grand Am
How to fix a door handle on a 1986 pontiac grand prix
Remove the inside door trim from the door
remove the weather protection from the inner door
panel
now look up inside the door and you should see a
small rod which is held onto the door handle with a
plastic fastener, pry the plastic fastener from the rod, it
just clips onto the rod so you only have to pry it from
the end of the clip to release it
slide the rod from the door handle, also remove any
other rods or cable that go to the handle
Use a thin extension arm with a socket to suit the nuts
or bolts that hold the handle in place, there should be a
few small holes directly behind the handle on the inner
panel
slide the socket extension arm with socket attached
through the holes and remove the nut or bolt holding
the handle in place
The instructions I am giving you may not be exact but it
should not be too much different if it is different at all.
Jul 11, 2010 | 1986 Pontiac Grand Prix
How do you change the inner tie rod and do you need a special tool or no
yes you need a tie rod end socket tool, this breaks the tie rod ball socket loose without damge to the grease boot.
Feb 23, 2010 | 1991 Chevrolet Lumina Apv
I have a stick shift car. the shifter came loose today. i took apart the console, and found where the shifter attached to a rod that lets it change gears. but, i can't figure out how to reattach it. it...
What you speak of is called a hiem joint. There has to be a sleeve or ring still on the trans rod the holds the ball in the socket. Look on the shift rod and see is it still there. If yes, pop the ball back in the socket and the ring back in on the ball, Find out what holds the ring in against the ball and fix that.
Jul 15, 2017 | 1998 Saturn SC
HP Compaq nx6120: power socket
Click Here For The Part And You'll Need A Soldering Iron And Some Solder.
Hope This Helps.
Sincerely,
Michael Scott
Jul 14, 2009 | HP Compaq nx6115 Notebook
Video Game Consoles & Games Logo
13 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
