Ge washer flashing lights
GE model GTUP240EM0WW, "on"light and "wash" light blink after tub fills.
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
SOURCE: washer does not drain water
Make sure the drain hose is not kinked
Posted on Jul 20, 2008
the dr
  • 447 Answers
SOURCE: GE WVSR1060A1WW washer will wash but will not drain/spin
Lid Switch either magnetic or mechanical
Posted on Nov 03, 2009
beltronic205
  • 1466 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
SOURCE: My GE space saver stackable washing machine will
Im haveing the same exact problem on the same exact machine... I have taken all the pannels off, and drained the water. I was wondering if there may be a way that the pump lost it's prime and needs to be re-primed? (wishfull thinking on my part.) There was no indication that the pump burnt out, it just stopped working instantly with no symptoms. The other functions seem to work, it will agitate the laundry, and then will just stop when it comes to the pump cycle. Any help is appreciated. Thank You.
Posted on Aug 05, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Ge washer will agitate or spin it will fill and drain water. have change lid switch and timer
If is is a top load model, check the motor's LED light. It will blink a series of blinks. there is a tech sheet located behind the control panel. it will tell you what the blinks mean and what to check and or replace. Probably motor or mode shifter.
Feb 18, 2015 | GE Washing Machines
Ge washer model grwn5150mows push start botton fill light flashes and nkothint happens
go to ge washingmachine.com ,put your model number in and you will see the problem,adrian..........
Jan 11, 2015 | GE Washing Machines
Ge washer tl1103pbwn
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
GE top loading washing machine drains and fills but does not agitate or spin. Wiring around lid switch resolved problem for one load only. Flashing green light on motor circuit board seven flashed each...
7 blinks DOES indicate a problem with the lid switch.
Replace the switch, and inspect the wiring for cracks/wear.
Can you hear the motor spinning?
Is there black plastic chunks under the washer?
What is the model #?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2010 | GE Washing Machines
Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Jan 04, 2009 | GE WBXR3100B Top Load Washer
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
