Question about Vacuums
How to insert filters - Vacuums
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vacuums Master
  • 102,366 Answers
Insert into what make and model vacuum?
Posted on Jul 10, 2013
Dyson DC16 keeps quitting.
Does red "charge status" lights pulsate when it quits?
If so the problem is with the filter. Access the main air filter (usually blue with white filter) , remove filter and note a small cylindrical metal insert -- this a magnet that is sensed to "insure" that the filter is in place before using. Fix: 1) try bending the filter so magnet makes better contact with sensor (sensor is buried in the plastic); 2) (this one worked for me) wad up some paper and carefully place behind just that part of filter to force the filter closer to the sensor -- this will require some patience but it can be done.
Feb 18, 2015 | Dyson DC-16 D12 Cordless Vacuum DC16...
Why does robot roomba 530 repeatedly stop and say to clean brushes
I think it's telling you to flip it over, open up the brush compartment, take the brushes out, remove everything wrapped around them, replace them and close it up. I suspect that your brushes are wrapped up with something.
Next open up the filter compartment, dump it into the trash, pop or slide out the filter and bang it into the trash can. Give it a quick rinse in the sink to wash off the fine dust still on the filter. Let it dry and insert it back into the filter compartment.
May 16, 2014 | iRobot Roomba 530 Robotic Vacuum
Where do you get filters for a EP366
TO ORDER REPLACEMENT DUST CUP FILTERS
To order, send check, money order or credit card authorization to:
EURO-PRO Operating LLC
94 Main Mill Street, Door 16
Plattsburgh, NY 12901
or call
EURO-PROCustomer Service at: 1 (800) 798-7398
Monday to Friday 8:30 A.M. -5:00 P.M. Eastern Standard Tim
Please Note:
The Shark Dust Cup Filters are washable.
Importan
Make sure that Dust Cup Filter is completely dry before inserting back in the hand vacuum
http://www.sharkclean.com/manual/EP366_(700_WATTS)_REV_0603A.pdf
Jul 27, 2013 | Euro-Pro Shark EP366 Handheld Vacuum
Roller ball stuck
Most common problem is the motor filter inside the ball is not inserted properly, or it has jumped out. Take off the access panel on the ball and make sure it is properly inserted.
Regards
Dyson Independent Expert
May 14, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Low suction
We have one of these a few years old without the ball, pull out and see what suction is like with just the hose and the attachment for it, am I wrong and it (yours ) does not have the pull up and out hose? low suction is almost always a blockage in the air path between motor and cannister.
Dec 13, 2012 | Dyson DC25 All Floors Bagless Upright...
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Dyson DC07 main filter can it be removed to clean?
Yes, remove the dust bin and set it aside. Using a small screw driver gently pry on the lid that the dust bin sits on. you'll see little holes to insert a screw driver and pry back on the lid. Start on one side and pry at the three points to insert a screw driver and then remove the lid and replace the HEPA filter with a new one from EBay, local vacuum store, Dyson direct, etc. That filter is not washable.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Joe
Nov 07, 2009 | Dyson Vacuums
I have a 10 gallon Shop.Vac 3.0 but I don't have the instruction booklet. Do I take off the pleated "paper" filter to vacuum up water? Do I use the vac with no filter for liquid?
Yes you should remove the filter for liquids. If the filter is not removed the internal float stop will not operate correctly. This will lead to the liquid being drawn up into the impeller and around the motor.
However I still like to have something in place because in most instances the liquid you vacuum up will not be without some solids. So I like to use a foam insert. Places like Home Depot carries a universal insert that works great.
Hope that helps.
Sep 17, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
