Question about Troy-Bilt tb516 ec lawn edger
Edger starts, revs up and idols fine. But the edger blad does not turn.
It will idol when choked apon release motor revs big and stalls
So it idles fine when the choke is on but not when its off, am I correct.
When the choke is on, the butterfly on the carb is closed. Meaning that Air is restricted upon entering the carb. This is telling me you still have a fueling issue. As when the butterfly is closed, the engine is getting the optimum amount of fuel and air to burn. However, when you release the choke, you open up the butterfly on the carb mean more air can get into the carb, in turn this draws more fuel through the carb to create that optimum burn.
Yours however isn't getting the fuel it needs when the butterfly is open, meaning its getting too much air and not enough fuel. Check and clean carb, replace any fatigued gaskets and diaphragms.
Apr 26, 2016 | Echo Used Trimmer Gt200r Outer Drive Tube...
How to put a bush cutting blad on
Meybe you can look up in google a user's manual for your unspecified Lawn Trimmer or Edger.
Just input terms
Manual and the undisclosed Make and Model of your device.
We can help you if you provide us this data,
Aug 08, 2015 | Garden
My vehicle has an idol issue. The performance of the vehicle is fine except just a little hesitation and idols high when coasting to a stopping point. When the vehicle comes to a complete stop the tru
Have you checked for vacuum leaks ?
Spray a small amount of starting fluid around all suspected areas and if it revs up that's where you leak is.
May 05, 2017 | Cars & Trucks
Idle speed for my volvo 850 too low. needs turning up slightly? when i start the car the idle revs are too low and car cuts out. but when its warmed up idling is fine.
Idol is controled by the computer. You need to run a diagnostic on the vehicle to determine what sensor is going bad. My best guess at this point is throttle position sensor or erg.
Apr 06, 2011 | 1995 Volvo 850
Makita RST210 grass trimmer not idoling and backfiring
your muffler has gotten full of carbon from the oil/gas mix you use and now theres too much back pressure and needs to be removed and cleaned or replaced,also while its off clean out the carbon deposits on the reed valves at the exhaust port
Mar 08, 2010 | Garden
I have the Toro edger/trimmer combo - which way does the edger blade bolt turn - I tried counter-clock-wise it won't budge. Also how to the LOCK the blade from turning??
on blad removal the nut goes opposite to tighten, lefty tighty, righty loosen. Put a metal wrench or rod in between the blade and the guard to keep the blade from moving.
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
My 99 accord goes into high idol when starting and if you touch the gas it revs high then low till i turn the car off . if i leave it on high idol after starting and dont touch the gas it eventually will...
check for air leaks on the emission system, if fine, check for the throthle posittioner disconect it, if idles good, replaceit, next go to the idle motor, is next to the throthle body, remove it and clean it with a good carburator cleaner, install it and start the car.
good luck.
Jul 08, 2009 | 1999 Honda Accord
2003 yz 125 stalling
sounds like the clutch is grabbing rip it apart and take a look
May 27, 2009 | 2003 Yamaha YZ 125
Troy-Bilt tb516 ec lawn edger Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
