Question about Cooktops
Miele KM310G ignition not working
The ignition has stopped working. I am wondering if I can replace it?
Hob igniter not working
Handbooks are available from Miele online. If that doesn't give an answer, you may need an appliance service person. I don't recommend you poke around yourself unless competent with gas and electrics.
Jul 21, 2014 | Miele Cooktops
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
1996 crown victoria has no ignition spark an wont start
Miele use pressure switches to activate the igniter pack if none of them work the fault is the igniter pack itself.
Feb 28, 2014 | Miele 23 in. KM360G Gas Cooktop
Hi I have a Miele KM32G that keep clicking on some burners. can you help
Hi jennifer20,
I believe those ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 27, 2011 | Miele 36 in. KM342 Gas Cooktop
Electric ignitors clicking
I'm sorry that I don't have a solution for you, but my Miele gas stove does the same thing. I had a repairman come out while it was under warrantee and they fixed it, but it was only temporary. It's doing it again, but, of course, it's no longer under warantee and will be very expensive to have Miele come out again. I've found that it's the right front burner that causes the clicking, so I've just stopped using it.
Apr 18, 2010 | Miele 36 in. KM342 Gas Cooktop
Piezo igniter keeps clickingeven afte burner is lit
the ignitor on my Miele gas cooktop keeps clicking without me touching it,how do I stop it?
Mar 21, 2010 | Miele 36 in. KM342 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Miele Gas hob KM326G 2 burners won't stop clicking
Hello Leighvz,
The rings around the burners should be cleaned periodically. Each one has a series of holes to let the gas come out and have to be set back perfectly or else you will continually have this problem. You can clean with regular dish soap an water and a sponge or rag.
Also, If you put a pot or pan on the burner and it is too large it will cut off oxygen to the burner causing your clicking. The clicking only occurs when the oxygen supply is not enough. Hope this helps
Sep 07, 2009 | Miele 35 in. KM326G Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
Cooktops Logo
21 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
