Question about Toshiba CF27H50 TV
15 yr old sony trinitron tv
The screen is green with horizontal lines & the picture flashes. We unplugged it and it worked for about 1/2 hr. We turned it off & the next time we tried it was green again. Now unplugging it doesn't help.
    Top Expert:
  • Toshiba Master
  • 74,136 Answers
It sounds that the video output section circuit bard to this TV have some loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. The video output section board can be located at the neck of the picture tube, will directly plugged on to it. Check it. If you wish to know more details about single color display screens, check this site. It has details to that problem. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Posted on Jul 11, 2013
  • 275 Answers
SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Posted on Sep 06, 2006
  • 3 Answers
SOURCE: Screen goes green with lines then shut off
shorted green cathode.
Posted on Oct 10, 2007
SOURCE: Green picture with horizontal green lines...
John,
First, Id like to know how old is your unit? Also, the lines indicates in issue with regards to the lifespan of your tube. The dominant green color has something to do with a malfunctioning ray gun of your tube. However, i had encounter a unit that was resolved by simply resoldering the circuitry of same problem.
Why dont you try to resolder the board first.
Response is highly appreciated.
chris
Posted on Mar 30, 2008
CAYPIANAN
  • 227 Answers
SOURCE: no picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Posted on Sep 30, 2008
  • 11800 Answers
SOURCE: My CRT TV displays a single horizontal white line
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Posted on Dec 21, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
HI,I HAVE A SCREEN FAULT ,WHEN TURNED ON I GET HORIZONTAL LINES OR LINES WITH A PICTURE AND SOUND.COULD THE T-BOARD BE THE PROBLEM.THANKS.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 28, 2014 | Televison & Video
No picture, green picture or horizontal bars
Aug 31, 2014 | Televison & Video
I have a 51HW40 sony TV. A few problems green horizontal retrace that curves flashes green and turns off (about 2 times a month) I wait turn it back on and its fine Codes that have been tripped: 6: Low b ...
Hello: Have you tried to adjust you Green Screen control on the focus block assembly. located behind the front panel assembly. Here is a solution that might help you, turn off the green by turning off this control, make sure u look at the block and make sure you are not turning the green focus knob instead of scrn crl. Turning the control slowly to the left the retrace lines should disappear as the green video darkens. Then turn the control slowly to the right just until the retrace lines reappear, then turn back slowly left just until the lines go away. If the screen is Blanking on green tube only then you have a video blanking problem on the main signal board. Or possibly a IK bias problem. It is also possible that the green CRT is defective. The FBT is not bad because the screens are lighting up indicating you have high voltageand heater voltage which is derived from one of the secondary windings of the FB. If it is a Blanking problem i would look into replacing the A Board assembly.
Sep 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Flashing green light and black screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Mar 12, 2017 | GE 13GP243 TV
I have a mitsubishi projection tv vs 6021 manf date may 1998. I have no picture no audio. the power swithc light is green and contiously flashes. Deos any one know what is wrong with it. thank you Denna
3 things will cause this and one wil be the problem. first off flashing green indicates protection mode.
Check for a faulty vertical chip. usualy removing it and briefly turning on the set will make the set work with a line across the middle of the screen. If the chip is the fault please replace the capacitors around the i.c as the fault will reaccur.
next check the horizontal out transistor , it should not be shorted between base and collector. if so check for dry joints around flyback trany and horizontal stage circuit.
last is the 8 volt regulator that supplies the micro its power. located on the power module.
Jul 07, 2008 | Televison & Video
Wd-52525
This chassis has bad capacitors on the PWB,FMt, DM and the other boards that need to be replaced. They are all jamicon capacitors 1000uf and larger there are roughly 10 in the set that need to be replaced. Let me know if you need further instructions on this model.
Apr 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
