Question about Car Audio & Video
Kenwood kvc1000 where can I get a loom for kvc-1000
  • 3,799 Answers
Try a kenwood store.
Posted on Jul 10, 2013
Cant find owners manual for kenwood KvC-670
Google it. It cones right up with a pdf link to download (which is why I can't post a link) also kvc is not a valid model number krc is
Jul 26, 2016 | Kenwood Car Audio & Video
Do you have the repair manuals for kenwood R1000?
About 4,860 results (0.45 seconds) Search Results
    [PDF]Kenwood - R-1000 Service Manual - IW2NMX
    www.iw2nmx.it/Kenwood%20.../R-1000%20Instruction%20and%20Ser...
    coei'f. capacitors) are detailed in the PARTS LlST, For the value of all common type components, refer to the schematic diagram of the PC board illustrationv ...
    [PDF]Kenwood - R-1000 User Manual - Textfiles.com
    pdf.textfiles.com/manuals/.../Kenwood-TRIO_R1000%20HF%20Comms...
    Page 1. Downloaded by. Amateur Radio Directory www.hamdirectory.info. Page 2. Page 3. Page 4. Page 5. Downloaded by. Amateur Radio Directory.
    RigPix Database - Kenwood/Trio - R-1000
    www.rigpix.com/kenwood/r1000.htm
    Apr 10, 2010 - Kenwood R-1000 ... Related documents: User manual (2.2MB, in english/german/french/spanish) Service manual (5.8 MB). Modifications:
Feb 08, 2016 | Kenwood Car Audio & Video
How do I swap the mechanism on kenwood kvc-1000 that flips the TV out?
kvc-pro-mac.en.softonic.com/
Not sure above the above address is what you need.
Jun 11, 2014 | JVC KVC-1000 Car Video Player
I need a wiring diagram for a 2006 dodge ram radio
Strongly recommend you buy a "snap on" Dodge - Kenwood adapter loom, from your local Auto Accessory store. This will save you cutting any wires, as these adapters are already pre-wired for plug and play and you can put your old radio back in at any stage.
Jan 20, 2013 | Kenwood KDC-MP235 CD Player
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Need a wire harness plug for a kdc319
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Dec 30, 2012 | Kenwood KDC-319 CD Player
Where does the orange and pink wire go to dpx303
You have only provided us with details on your Kenwood Receiver, but not the vehicle make or model.
Therefore, I can only answer based on the Kenwood receiver wiring.
The Kenwood receiver loom has an ORANGE (White stripe) wire - this connects to your vehicle's "Dimmer" control wire.
Kenwood receiver loom does not have a Pink wire.
Hope this helps.
Dec 18, 2012 | Kenwood DPX303 CD receiver
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
