Change from lower case upper case
If there are more than 2 symbols on a key and I use the "caps" key the text will show the one on the upper right instead of the one directly above as is usual. This happens from time to time and I generally close my computer and start again but it keeps happening and having to close everything in a project is frustrating. Is there a way to change it back ( and know what I might have done to make it happen) without closing and rebooting?? I thiunk it the the French setting but have checked the keyboard settings and they are Canadian /US
  • 142 Answers
Have you tried re-installing your input device drivers such as your keyboard? Are you using PS2 keyboard ? if yes then please try to check the pins on each pair
Posted on Jul 10, 2013
janelu
  • 93 Answers
SOURCE: HP Laptop keyboard fails... sporadically
It will happened if you hold 'Shift" key so such long time.
Posted on Nov 26, 2008
odiegh
  • 81 Answers
SOURCE: how do I switch from the green keys to my regular keys?
it sounds like you have turned on either your language bar settings and sometimes switch to another language, there is a function key you are hitting causing the keys to lock on that setting
Posted on Apr 01, 2009
  • 123 Answers
SOURCE: HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Posted on Jul 31, 2009
  • 211 Answers
SOURCE: Screen keeps blanking out on my Dell Inspiron 1501 :(
Could be faulty inverter board or faulty LCD backlight.
To determine which one is faulty, you have to replace inverter board or LCD screen, but i think that you don't have another inverter board or screen to test, so i'm recommending you to buy new screen with inverter attached to it.
Pick any screen from here
And here is how to replace it.
Posted on Aug 22, 2009
  • 7993 Answers
SOURCE: Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
Posted on Sep 05, 2009
Testimonial: "Thanks for the confirmation. I kinda figured it was a one time option."
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I cannot text in lower case. How do I change from
When in text mode, press 1 (one) then press 0 (zero). That works on my Motorola Tracfone.
Jan 17, 2010 | Motorola Mobility TracFone® V170 Cellular...
I cannot figure out how to get my phone off all caps for texting
While on the message editor, press 0 to switch from lower to upper case and vice versa.
Oct 09, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Changing to capital letters in texts.
i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
Mar 11, 2009 | Motorola Mobility L71 Cellular Phone
Changing text message entry text from upper case to lower case
to change from upper case to lower case.press and hold down the number sign button,and the different case would show up on the top of your text message.
Aug 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Hello
copy all text past in to microsoft word. select all text press function key F3 this wil change case upper and lower and tile case. u can switch which type u want
Mar 01, 2008 | Computers & Internet
Turn off the predictive text for E250
it is the same key as to change case. If you press it repeatedly, it'll cycle through various options in the top right of the screen:
initial caps with predictive,
all caps predictive,
lower case predictive,
numbers,
initial caps without predictive,
all caps without predictive,
lower case without predictive.
When T9 is not displayed, predictive text is off.
Just to spice things up, Samsung's idiotic software designers made it so that depending on the situation you're inputting text, the order that things cycle through is different, so you can't just press it a certain number of times to turn it off, you have to pay attention to the icon in the top right.
Nov 26, 2007 | Samsung SGH-D900 Cellular Phone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
