Question about Samsung Falcon iDCS 28D 28-Button Keyset with LCD - Dark Gray
OVERRIDE PASSWORD ON SAMSUNG IDCS 28D
We have had an employee leave and have no access to the password on their extension. How do you override the password to gain access to the voicemail system?
  • 19 Answers
SOURCE: forgot my password to get into my text messages
call the phone company they will reset it
Posted on Jun 02, 2009
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Posted on Aug 06, 2009
SOURCE: I have a Samsung iDCS
Regarding "Same Problem": Probably said "unavailiable CBT"? In that case it's because a call button hasn't been programmed into the keyset.
Posted on May 27, 2010
PhoneSystems
  • 213 Answers
SOURCE: how do i change my voicemail greeting on my
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
Posted on Jan 14, 2011
PhoneSystems
  • 213 Answers
SOURCE: We have a Samsung idcs
Hi, unfortunately you have to go in via the engineering passcodes, your telecoms supplier should be able to help with this. there is written instruction regarding Voice Mail on http://www.abbeytelecom
Posted on Jun 20, 2011
How do yo block a number on samsung idcs 28d?
^67 then dial the number. Test it out first by calling a phone of your own with caller ID. Also try turning off the "Show Caller ID" in the settings.
Aug 05, 2014 | Samsung Falcon iDCS 28D 28-Button Keyset...
Flashing red light with no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 30, 2013 | Samsung Falcon iDCS 28D 28-Button Keyset...
How do you reset the password on a Samsung iDCS 28D
From the Subscriber Services Menu, Press [#] [7] [1] ....you will then hear the old password XXXXX you will be able to change it...
The Manual for a typical Samsung iDCS system is available here....
http://www.samsungidcsphonesystems.com/pdf files/idcs 16/iDCS_16_user_ins.pdf
Jul 20, 2012 | Samsung Falcon iDCS 28D 28-Button Keyset...
We have a Samsung idcs 28d system. How do I prevent an all-page announcement at my station?
Hi Rachel, you need to remove your extension from the page groups, to do this;
press TRANSFER - 200 - 1234 - 1 - SPEAKER KEY
press 604.
using the 3rd softkey and your volume key when the cursor is under the 'members' find your extension number and press HOLD to delete yourself.
I have posted a video which actually shows how to add members to a group, this will give you an idea how to do the above, or for more tips go to http://www.abbeytelecom.com.
Hope that this helps
May 23, 2011 | Samsung DCS 12 Corded Phone
I have a problem with my Samsung iDCS 28D phone. All incoming calls used to be routed to me by default (unless caller specifically punched in a different extension). Calls are now being routed directly to...
try dialing 600 to clear call forwarding, then re-set your forwarding to busy/ no answer followed by the VM number.
I have uploaded a 'how to' video, more of these are at http://www.abbeytelecom.com
I hope this helps.
May 12, 2011 | Samsung DCS 12 Corded Phone
I have a samsung idcs 28d keyset, and the phone is working but when I try to dial out it brings up the message SETUP_ACK msg! and it wont allow me to dial out or people to dial in, but I can still dial...
Don't know the model but if it is a PBX phone you have to program it to call out if you have extensions dial 9 to get out and so on ,its a lengthy process .Check your manual.
Mar 28, 2011 | Samsung DCS 12 Corded Phone
I have a network of samsungiDCS 28D phones. The phone in my office does not ring or show caller id. I want it to ring and show caller ID, how do I program it?
Hi you need to add your extension to the group that your phone rings in to. usually this is gruop 500. you can check this in MMC 714 in customer programming. I have attached a video showing how to add members to groups, there are 60+ relating to the Samsung iDCS range at www.abbeytelecom.com
Mar 10, 2010 | Samsung DCS 12 Corded Phone
Aug 03, 2009 | Samsung DCS 12 Corded Phone
How do I change the voice mail recorded message? How do I get a manual for this existing system?
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
Jun 08, 2008 | Toshiba DKT-2010 Corded Phone
Open Questions:
See all Samsung Falcon iDCS 28D 28-Button Keyset with LCD Questions
Samsung Falcon iDCS 28D 28-Button Keyset with LCD - Dark Gray Logo
62 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
