Question about Cuisinart Professional Ice Cream Maker
Cuisinart professional icecream maker
The mixing blade stopped turning, so I bought a new arm. Th new arm doesn't turn the blade either. There is power going to the motor & from the main body of the machine to the arm, but I don't understand why the blade won't turn?
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: mixing arm/bowl will not turn once machine is turned on
The only thing I can really suggest is to make sure the easy-lock button is fitted into the right place on the lid, and to make sure that the ice cream mixture is not too thick. But, if the turning paddle is locked into place properly, and the mixture is still in liquid form, then there is a problem with one of several parts - could be the metal sliding switch or even a motorized part. These parts cannot be replaced. It is worth a shot to replace the mixing paddle - the unit has a 3-year warranty, so I would Call Cuisinart to get the part instead of ordering it online - they may or may not give it to you for free. If the new mixing paddle still won't spin, get the unit replaced either thorugh the store (depending on the store -each has a different policy) or get it replaced directly through Cuisinart. This model is actually pretty solid, so a second one shouldn't give you any problems.
-Tha Mp3 Doctor
Posted on Mar 08, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
jennable
  • 24 Answers
SOURCE: Ijust purchased a cuisinart table top icecream
http://www.cuisinart.com/products/ice_cream/ice-45.html
Click on "Download Manual"
Posted on Dec 17, 2009
  • 22 Answers
SOURCE: Hi, I hav bought an ICE-50BC ice cream maker. It
See the BOLD section below..
You need a good simple recipe. So here is one.
(This is an unpasteurized recipe unless you boil the blended strawberries, wash the berries very well if you don't)
1 lb fresh strawberries (ripe is better)
3/4 cup sugar (most folks double this but i prefer the taste of strawberry)
3/4 cup whipping creme
2 1/4 cups milk (2%)
1 tsp lemon juice
Liquefy the strawberries in your blender. (Boil now if pasteurizing) and add the rest of the ingredients and blend.
You now have enough Ice cream mix for two partial batches. Divide mix in two equal portions. You should have enough to fill machines bucket 1/2 - 2/3 full.
IMPORTANT
Do NOT have more or less in the bucket as the machine screws up with more or less of any mix.
Insert Paddle and put noisy grey power arm on top.
Add a 2 inch thick hardcover novel on top of arm above bucket.
Add a heavy Soup can on top of this book (I recommend Habitant French Canadian Pea Soup 28 fl oz size).
Set timer to 40 minutes.
Leave room as it is a noisy little beast machine.
Come back and check just before it is done. If still too liquid add 5 minutes to timer.
Empty into bowl and add 2nd half of mix to bucket.
Clean the dimple on bottom of mixer paddle before putting back in bucket. This batch should take 5 minutes less as compressor is already cold.
Have fun.
The book and Soup can are essential to keep the silly beasts power arm from lifting up too early.
Posted on Jun 28, 2011
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Hi, I hav bought an ICE-50BC ice cream maker. It is now 3 weeks old & has been used 3 times. When the ice cream begins to freeze the stirrer arm always lifts off the machine & stops working. when I...
1 tsp lemon juice
IMPORTANT
Have fun.
Apr 28, 2011 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
The motor arm seems extremely loud. Machine is
Run the machine in another room.
It is due to Cuisinart's cheapo motor.
Also try 1/2 to 2/3 fill batches.
Put a book and a medium food can on top of motor arm to keep it from lifting while mixing.
Jan 25, 2010 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
How to make icecream in cuisinart ice 50bc
1 tsp lemon juice
IMPORTANT
Have fun.
Oct 21, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Mixing arm/bowl will not turn once machine is turned on
-Tha Mp3 Doctor
Mar 05, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cuisinart ICE-20 AND TURNING PROBLEM
The problem is either the mixing paddle itself or the lid that it fits into - both parts can be ordered from Cuisinart.
Aug 09, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
-Tha Mp3 Doctor
Jun 04, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Does not work
same problem. looking for solution(s). Got 3-4 good batches out of it, then it stopped properly freezing.
Mar 28, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Cuisinart Professional Ice Cream Maker Logo
Top Cuisinart Ice Cream Makers Experts
Jay Finke
Jay Finke
Oloyede Monsuru
Ruth summersides
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
