Question about Cuisinart Professional Ice Cream Maker
Blade wont turn
The blade stopped turning, so I bought a new arm...which still isn't turning. There is power going to the motor & from the machine to the arm - why wouldn't the blade not be turning?
8756 machine freezing up and icecream to thick what can it do to change problem
You can adjust the viscosity.
In soft serve and frozen yogurt machines, the logic board X36641SER2Refurbished Gen 2 Logic Board This item is sold with exchange...measures the viscosity of the product by monitoring the amp draw of the beater motor. When the machine reaches the set point, it cycles off and the product is ready. In auto mode, you can only adjust product viscosity, temperature in the freezing cylinder is not monitored.
The power board measures the amp draw. L1 power supplied to the beater motor goes through the power board on the beater terminals. Single phase and three phase units use the same Softech control, so the power board allows for different amp draw ranges. A jumper on the power board determines the amp draw range. Place the jumper on the pin that corresponds to the amp draw of the beater motor when the product is at the desired viscosity.
Setting Viscosity Adjustment
1. Place an amp probe on one of the L1 leads on the beater terminal on the power board.
2. Turn the viscosity adjustment screw to the "MAX" position.
3. With the freezer properly primed, press "AUTO".
4. During the freezing process, draw samples and inspect the product appearance. When the desired product viscosity and appearance is achieved, note the beater amperage.
5. Press "AUTO" to cancel the refrigeration cycle.
6. Using the chart, set what range the beater motor amperage falls into and place the jumper on the corresponding pin.
Viscosity Control Chart
2.4 pin - 1.2 amp to 2.4 amp
5.0 pin - 2.5 amp to 5.0 amp
8.0 pin - 5.7 amp to 11.2 amp
7. Press "AUTO". When amperage reaches the noted draw, turn the viscosity adjustment screw SLOWLY until the unit cycles off.
8. Draw several samples to verify the product and amperage when the machine cycles off remain consistent.
Adjusting Viscosity
To increase viscosity, or make the product harder, turn the dial clockwise towards maximum. Important: The dial only turns a limited amount if it stops turning do not force it.
To decrease the viscosity, or make the product softer, turn the dial counter-clockwise towards minimum. The dial only turns a limited amount do not force it once it stops.
We recommend you only turn the dial about 1 hour on the clock, at a time. Once you have made your adjustment, pull the handle to start a new cycle, when the machine cycles off check the product again.
adjusting viscosity on taylor frozen yogurt machine-5jpt2eusobswb402obrm5sjf-2-0.png
Jun 06, 2017 | Ice Cream Makers
How to find why 339-27 taylor not good product viscosity?
It could be a couple things. The most common is worn down scraper blades. Try new ones first. Worn scraper blades don't scrapers the cylinder walls and the ice cream that's stuck on the walls acts like insulation and it will take a lot longer to freeze this ice cream. If that doesn't solve the problem then you are likely low on refrigerant on that side. Your machine measures the viscosity by reading the amp draw of the beater motor. The harder the ice cream gets, the harder the motor works. If the ice cream isn't getting hard enough because of one of the reasons above, your machine wont shut off.
www.softserveparts.com
May 26, 2017 | Taylor Ice Cream Makers
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
Hi, I hav bought an ICE-50BC ice cream maker. It is now 3 weeks old & has been used 3 times. When the ice cream begins to freeze the stirrer arm always lifts off the machine & stops working. when I...
See the BOLD section below..
You need a good simple recipe. So here is one.
(This is an unpasteurized recipe unless you boil the blended strawberries, wash the berries very well if you don't)
1 lb fresh strawberries (ripe is better)
3/4 cup sugar (most folks double this but i prefer the taste of strawberry)
3/4 cup whipping creme
2 1/4 cups milk (2%)
1 tsp lemon juice
Liquefy the strawberries in your blender. (Boil now if pasteurizing) and add the rest of the ingredients and blend.
You now have enough Ice cream mix for two partial batches. Divide mix in two equal portions. You should have enough to fill machines bucket 1/2 - 2/3 full.
IMPORTANT
Do NOT have more or less in the bucket as the machine screws up with more or less of any mix.
Insert Paddle and put noisy grey power arm on top.
Add a 2 inch thick hardcover novel on top of arm above bucket.
Add a heavy Soup can on top of this book (I recommend Habitant French Canadian Pea Soup 28 fl oz size).
Set timer to 40 minutes.
Leave room as it is a noisy little beast machine.
Come back and check just before it is done. If still too liquid add 5 minutes to timer.
Empty into bowl and add 2nd half of mix to bucket.
Clean the dimple on bottom of mixer paddle before putting back in bucket. This batch should take 5 minutes less as compressor is already cold.
Have fun.
The book and Soup can are essential to keep the silly beasts power arm from lifting up too early.
Apr 28, 2011 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
The motor works but won't turn the blade. As soon as I turn it on, it sounds like it gets stuck and stops. What is going on?
The inner gears are probably stripping. This seems to be common on the rival 8550-X-5. I will never own another rival because mine was that way almost from the start.
Jun 29, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Suspected motor burnout
Yes I too would guess motor burnout ( Motor is very overworked as ice cream hardens) You could replace the motor but I would suggest buying a new one because the cost of a major repair like that may very well cost more then a new unit!
I hope I answered the question to your satisfaction!
Please rate my response!
Thank You!
Jan 26, 2009 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Blade stops turning but motor still running
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Jun 14, 2008 | Simac Ice Cream Makers
Motor Arm stopped working
All i can suggest is cleaning the contacts. Clean the metal prongs and the two holes they go into.
UNPLUG THE MACHINE
Use a q-tip cotton swab dipped in hydrogen peroxide or rubbing alcohol ... not both. After cleaning one hole wipe off any excess fluid before cleaning the other hole. These holes are a natural for catching stray drips of food or other kitchen goo.
Good luck.
Jan 13, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Cuisinart Professional Ice Cream Maker Logo
Top Cuisinart Ice Cream Makers Experts
Jay Finke
Jay Finke
Oloyede Monsuru
Ruth summersides
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
