Toshiba tlp xd2000 red light standby, not working
Changd bulb and it came righ ton. tried to use today and back to the red light flashing on standby
  • 179 Answers
SOURCE: standby light flashes
the lamp thermal sensor is probably bad...you ma also have a lot of dust around the lamp fan..there is a service kit for this problem.
a1137954a..you must clean all the dust from the fan above the lamp or replace it.
Posted on Nov 28, 2007
Slinteriors
  • 8617 Answers
SOURCE: sony bravia 50" rear projection hd 3lcd tv
3 blinks in sony sets means B+ over current protection shutdown. Problem in power supply Check Transistor T603 And Resistor R672. Hope this helps let me know if you need any further assistance.
Posted on Jan 08, 2008
  • 6 Answers
SOURCE: Toshiba 65H81 blank screen and red blinking light....help
I don't think is any lamps.
If you are handy try to open the back of your tv, (unplug it first) don't touch anything just yet, you need to make sure you discharge any static left on the power board (the first from your left )Unplug power cord from the board. Take a heavy long screwdriver (Isolated) and lightly, touch a few parts on the board including the thick red wires that go to the lamps. Once that's done its time to put your dexterity at work. You need to lift that board (PD 0074) so that you can check some fuses like F850, F852, etc. for continuity. Mine were out. I had replaced those two and I had tv for another year. Remove the screws that hold the board. Now, this board PD0074 is connected to the next board by two white connectors and one blue. ....lift them up from one side with your finger nail. Don't unplug anything from the power board, just loose some wires so that you can lift the whole board on one edge. Get a voltmeter and set it to check continuity. Mine has a buzz. Look for them fuses if they are bad , ....replace them. (You can buy them at Partstore.com.....punch in "fuses"or "125V 2A")
In my case that was the only problem a year ago. Now I also have the same problem but this trick didn't work for me anymore. The Power Co,. messed me up big this time. In fact the problem with these Toshiba rear proj. is that when the power in your house goes out and comes back right a way in a split second and you don't have a power regulator, guess what : 'red led blinking'
In my case this time the whole power went on and off a few times within 10 sec. and by the time I got to the TV to unplug, it was to late. I think I have to replace the whole PD0074 board....and that's expensive.
Good luck
Posted on Mar 10, 2008
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
  • 36 Answers
SOURCE: red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Posted on Feb 10, 2009
Toshiba TLP-T60M fan error
I just had the same problem, you have an idea on this?
Nov 26, 2012 | Office Equipment & Supplies
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Reset lamp hours toshiba tlp xd2000
"menu""input""enter" hold in the on position
Mar 02, 2012 | Toshiba TLP-XD2000U Mobile Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
My Toshiba TLP-XD2000 projector reads "unsupported signal" when it is plugged in to my Dell Inspiron 600m laptop. It has worked for about 8 months perfectly and then when I plugged it into another computer...
reset the settings to factory default. when you plugged it into the 2nd computer, it searched for matching resolution, to no avail. when you put it back with yours, it was on the default setting.
Jun 23, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba lcd projectors tlp xc 2500
Verify "Key Lock" function is not enabled
Jun 14, 2009 | Toshiba Replacement Projector Bulb...
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Power on?
im looking for this solution also
Feb 27, 2008 | Toshiba 44NHM84 44" TV
Blub goes out during use.
Most fans have a sense line to detect the fan is working properly, Possible the sense circuit has failed. The unit should not start if it thinks the fans are not running. Possible thermal problem with the sense circuit, since your unit starts up then stops.
Mar 10, 2007 | Toshiba TLP-ET1 Multimedia Projector
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
