Question about Kenmore Dishwashers
Reset for dishwasher
Quick rinse light flashing,dishwasher will not respond to any button.is there a reset for this model?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 102,366 Answers
What model Kenmore dishwasher?
Posted on Jul 10, 2013
SOURCE: blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
Posted on May 08, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
SOURCE: i have a kenmore dishwasher mode 665.16032402
I was able to reset it using this procedure:
1. Crack the dook open
2. Within 3 seconds, press these buttons in this squence: Hi Temp Wash, Heated dry, Hi Temp Wash, Heated Dry
3. Close door
4. Press Cancel
That should clear the Blinking LED. It appears this is a common problem. The worst thing is they charge to come out for this.
Posted on Jan 13, 2010
  • 395 Answers
SOURCE: Dishwasher won't start. The Quick Rinse light is
The light blinking indicates that the program is ready to start but has not received the go signal from the Start / Stop b utton as the switch is probably faulty.
Try to reset the machine by disconnecting the mains power, waiting at least 10 seconds and then reconnecting. Try to start the machine in the normal way and if it still will not start then it means that the switck control is faulty or the control unit has a fault.
Yo will probably have to call a dishwasher technician to rectify the problem.
Posted on Jan 10, 2011
  • 202 Answers
SOURCE: The normal wash light is
Hi... you need a new control board ... seen this lots of times
Posted on Mar 29, 2011
Testimonial: "Daddy2keagan knows his stuff."
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Flashing quick rinse light on panel
I had the same problem but I found someone wh said that there is a way to reset the dishwasher. I tried it and it has worked so far.
Here is what I did.
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Oct 24, 2007 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
