Question about Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat will not turn on
My gigabeat just stopped working, i plugged it into charge thinking it would turn on then, but it said something about needing to be repaired.I tried it a few other times,but not it will not turn on at all.Is there any way i could get it back on?
  • 5 more comments
  • Ilpirata Nov 12, 2007
    Out of the blue my gigabeat will not turn on when I hold down the power switch it does not show that it is charging when i plug it into the USB cable or directly to the power source I have tried resetting the battery button and the hold button and it will not turn on or show ANYTHING on the screen.
  • amanda7405 Dec 25, 2007
    my gigabeat did the same thing after it got dropped. theres now a white screen and is will charge and i can put songs on it, but the screen is still white. do you know how to fix it?
  • pacostacos88 Mar 04, 2008
    yep. I had the same prob. wouldn't recharge, blank screen I was pissed. But the resetting of the battery switch a couple times solved my probs Thanks.
  • johnadams Apr 11, 2008
    My gigabeat just wont turn on or even charge.
  • Dennis Ponce May 23, 2008
    I dont know why my MP3 player is not ON. I tried to reset the battery on and off but doesnot work . I need help.
  • claudia_17 Jun 10, 2008
    I turn it on but i keeps telling me to cantact a manufacturer for repair.
  • scratchman Jul 17, 2008
    I was at the gym and it just stopped working and the screen went off. Pushed the on button and nothing happened. Turned it off and back on on the bottom switch and nothing happened. Plugged in to the usb port and nothing happened.
    Problem Solver:
  • 6 Answers
I had similar problem, I turned the unit on and non of the buttons worked. I open the top cover off and found that the battery swelled up and bacically it holding the touch pad constantly. I left the cover off and it function normally, to put the cover back on the problem comes back. Need to replace the battery!!!!
Posted on Jun 03, 2008
I had the exact same problem Allii366, and it turns out all I had to do was reset the battery switch, and it accepted being charged again.
I hope this helps man.
Posted on Oct 24, 2007
SOURCE:
My T400 windows embeded toshiba gigabeat is fully charged and is not turning on. what should i do? i plugged it into my windows xp computer and my computer told me the USB device that is connected is...
sounds like something inside has shorted or blown. when you plugged it into windows did it say power surge on hub or did it say USB Device not recognized
Mar 03, 2011 | Toshiba Gigabeat T400 MP3 Player
My Toshiba Gigabeat won't work!
This happens when the Gigabeat battery is run down too far. The only hope is to charge it with the AC charger.
If you don't have one, you can probably get something adequate. The standard adaptor is p/n ADP-15HH, 5V 3A output, center positive, take the unit with you and match the connector - I don't have a useful ruler handy.
If you do not have or cannot get an adaptor, try plugging the device into a USB port and wait at least a day, no kidding. If you can get the port to kick in fir high current, it may come back to life. My Ubuntu box has done it once, as a test.
You can only avoid this by charging the Gigabeat before it runs down too much. This is the real weakness of the Gigabeat, IMHO. That and the problems they get losing the firmware, but that's another topic.
You can sometimes find chargers on eBay, but you will have to pay a little...
Feb 17, 2009 | Toshiba gigabeat MES60VK Digital Media...
My gigabeat only works with the charger plugged in
does it show the charge icon?
maybe you should replace your batteries.
May 10, 2008 | Toshiba gigabeat S MP3 Player
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Battery Problem
Try your luck charging thro' USB port from a PC
Aug 26, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Jul 29, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat wont Mount or Sync
Hi Ben, Make sure you have Windows Media PLayer 10 installed and working or download "Gigabeat Home" - that might help. Good luck. JayMac
Feb 23, 2007 | Toshiba gigabeat S MP3 Player
It thinks its still plugged into the USB
Turn the battery button to the off position. It seems to work when I do it to mine. Good Luck.
Jan 09, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
106 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
