Kenmore dishwasher model #665 15822000
QUICK RINSE LIGHT IS FLASHING AND DISHWASHER WILL NOT WORK.IS THERE A RESET FOR THIS MODEL?
yalmer
  • 549 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
SOURCE: I have a kenmore ultra wash dishwasher. For some
I have the same problem tonight!!! Did you find a solution??? matts268@comcast.net
Posted on Jun 29, 2010
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Posted on Dec 13, 2010
Reset for dishwasher
What model Kenmore dishwasher?
Jul 10, 2013 | Kenmore Dishwashers
Why won't my Kenmore dishwasher display work properly?
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Kenmore dishwasher 16764 Quick Rinse Light won't go off
you can try reseating the ribbon cable on the board however i strongly believe you have a stuck key and the key panel will need to be replaced.
Feb 02, 2009 | Kenmore 16764 Dishwasher
Model#665.15829000 kenmore
sounds like you have a stuck key pad on the touch control board. there is no easy way to check this, but you can unplug the "ribbon" strip from the control board. then you will need to jumper the board to see if you can force the unit to run by bypassing the key pad.
i cant find an exact match for your model number, but if you check the wiring diagram, behind the lower access panel, it will show you which 2 terminals can turn on a cycle.
the best thing i can tell you is to just replace the control panel with a touch pad assembly. it could cost about 125-150 bucks, but that should fix the problem.
Jan 30, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Apr 21, 2008 | Kenmore 15919 Built-in Dishwasher
Flashing quick rinse light on panel
I had the same problem but I found someone wh said that there is a way to reset the dishwasher. I tried it and it has worked so far.
Here is what I did.
Oct 24, 2007 | Kenmore 15769 Built-in Dishwasher
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
