Question about Stanley Air Tools & Compressors
Install thumb latch - Stanley Air Tools & Compressors
Shop Vac lid will not securely latch. 1
Are you sure that the filter is pushed all the way to the bottom of the container? Just take it out and put it back and make sure the filter retainer is gently turned all the way.
May 19, 2013 | Shop Vac Vacuums
Why won't the door latch extend fully anymore? It extended fully for a few days after being installed.
Why does the interior knob or lever on my front entry handleset sometimes cause the latch mechanism to jam and the exterior thumb press to lock in place?If the front entry handleset is newly installed, the latch mechanism may be binding. If the exterior handleset is left sitting in the bottom of the bore hole through the door, the rectangular spindle that extends through the latch may be somewhat tilted and binding. This can be checked by loosening all screws, slightly lifting the exterior handle, and then tightening the screws before releasing the handle. This may make the spindle more level with the latch and eliminate the binding. If this does not resolve the problem, or the handleset has been installed for some time before the problem occurs, the latch mechanism may be failing and need to be replaced.
May 03, 2011 | Schlage FE365-CAM-ACC Lifetime Polished...
Maytag Neptune MAH5500BWW washer thinks the door is unlocked when it is actually locked. Do I replace the door latch assembly, the control board, or both?
Sorry to read about your problem, I hope this helps you out.
no their is a door safety switch, that maybe defective. or a bad door latch assembly part #22004435 cost around $110.00.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
The soap despenser doesnt pop open during a wash cycle the spring on the lid is ok and the latch spring seams ok we have tried running the hot water in the sink first so that water in the dishwasher is hot...
It will not open on a regular cycle,or normal wash, it will only open on heavy or pot scrubber..
if you are using the heavy setting, and its not working, you have a latch relay problem.
i suggest you contact a service company
3 Thumbs - Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Dishwashers
My dishwasher id a GLD2445RF and it keep flashing CL and on the codes it says to close the door and lock. What else can i do? I made sure it was closed and you can hear it latch.
you must have a defective latch switch, i suggest you contact a service company..
3 Thumbs - Helpful
Dec 27, 2010 | Dishwashers
Freezer doorpops open when close other door. 6yr old profile attica. no obstruction and seal appears ok?
The gasket seals are getting weak.
3 Thumbs - Helpful
Dec 27, 2010 | GE Freezers
DEADBOLT INSTALLATION PROBLEM
Did you cut the bar to the correct lenght?(the flat or square one that connects to the thumb latch or other cylinder?) Too long and you'll bind the lock.Good Luck
Sep 15, 2009 | Kwikset Brz Sgl Cyl Deadbolt
Toshiba Satallite Wont start up
Gently remove and clean (with a pencil eraser) and reinstall your memory, then try again.
For you non-techies, it is very easy to hose a perfectly good laptop by NOT fully releasing the side-latches (some metal, some plastic) BEFORE gently lifting the RAM up 1/4", away from the pin/contact seating area, and OUT of the sockets. Actually, if you do it right and do not physically touch the face, sides or corners of the RAM when you use your Left and Right thumbnails to 'tease' the latches away from the sides of the RAM, it will POP out all by itself. smile1.gif
Now... putting new RAM in is REALLY easy and does not require any force or pressure at all. Look at the socket and the RAM and orient your RAM so the slot in it (the RAM) and the raised portion of plastic in the contact seating area line up. If it is OBVIOUSLY not, flip the RAM over and check again. If it still will not, or can not line up... it is the wrong type RAM for your machine. Take it back. Do not try to 'make it fit' ;-)
Once you have RAM oriented so it WILL slot in, take the RAM between your index fingers and thumbs so the contacts are facing AWAY from you and hold firmly by putting the tips of your fingers into the holes on the sides of the RAM, ease the RAM into the socket and seating area, wiggle a bit side to side and seat in snugly, then maintaining the hold with your 2 Thumbs, tease the latches away from the socket edges with your fingernails (under the edges of the new RAM) so they both clear the sides of that RAM, then gently press down a bit further with your thumbs until the RAM face is below the latches and finally release the latches making sure BOTH are now above the RAM face. Done.
Don't FORCE... EVER ;-)
Hope that helps
Apr 05, 2009 | Toshiba Satellite A105 Notebook
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
Jan 03, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Air Tools & Compressors Logo
23 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
