Question about Crafts & Hobbies
Fixing my sewing machine
Wobbles in your hand won't raise needle up or down
  • 4 Answers
Take it to the nierest enginer in ur area
Posted on Jul 10, 2013
Sewing needle won't move
it could be a part is damaged or broken or a timing problem,,it
would be a good idea to have the machine checked.
Dec 09, 2012 | Sewing Machines
Feed dogs won't move
No info on the sewing machine make or model. It sounds like something is binding up, is bent, or is tangled in the machine. Look around the front and back of the sewing area for a switch to lower the feed dogs.
Good luck
Oct 05, 2012 | Sewing Machines
Needle won't raise all the way
it would be a good idea to have the machine checked at a sewing machine
shop
May 19, 2012 | Singer Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
I was sewing everything was fine. When I changed to zig zag it also worked but, when I switched to straight sewing and pressed the foot peddle the machine began to make a beeping sound and it won't go...
If the needle was on the down position when you switched stiches, this could have caused the problem. Raise the needle completely, power the machine off for 30 seconds, then power back on... Did that fix it?
Jun 22, 2011 | Singer 7436 - INGENUITY
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Crafts & Hobbies Logo
226 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
