Question about Sub-Zero 680 / F
Paint on ice maker housing chipping into ice - Sub-Zero 680 / F
  • Sub-Zero Master
  • 15,950 Answers
Duplicate post
Posted on Jul 10, 2013
Water dripping in fridge from below frezer
There is a drain tube that runs from the freezer/ evaporator compartment that allows ice melt water to drain from the defrosting cycle. Often times that drain hole will become clogged with food debris, glass from a broken heating element, paint chips from scaling and mildew, etc. When that drain hole gets clogged the water has no place to go except down into the fresh food compartment. Unplug the ref and remove the food and ice maker and racks. Remove the freezer back panel and look for a drain hole and clean it out. I use a wet/ dry vacuum at first and if the clog is deeper I will use compressed air to blow the line clear. You can also use a water hose with water pressure. Best done outside of the house.
Feb 09, 2014 | Refrigerators
Ice Maker No Longer Working
The icemaker contains an electric motor. You might have drowned it.
Nov 13, 2013 | Kenmore Refrigerators
Paint Chipping
Are you sure that it is the paint and not calcium or nitrate deposits?
Jul 10, 2013 | Sub-Zero 680 / F
Ice maker ice dam
turn the ice maker off, take out the ice box and let all the ice melt try a knkfe in the ice maker to chip away whats clogged. it worked on mine but its not permanent. good luck
Aug 27, 2012 | Whirlpool Refrigerators
Sub Zero ice cubes with black paint chips
HI, You will need to change the ice maker. You are getting the paint from then coating inside the cube tray.
Vic
May 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
Black on ice
i would inspect the "black dots " a little closer, the ice maker mould itself is painted with black teflon fininsh if indeed the mould paint is peeling id empty that ice and replace the icemaker
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Black specks in the ice
I have the same problem and haven't solved it yet. I have a brand new water heater. A retired carpenter/contractor (47 years) posted this, saying that he knew what it was right away. He said it was the deep well pump. (I do have a well). The seal in it had broke and was leaking oil into the water. Every time the pump would come on it would stir up the tiny bit of oil, enough to make it look like a barrel. I haven't had mine checked yet, but it certainly makes sense to me.
Mar 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
PEELING PAINT INSIDE A SMALL U-LINE ICEMAKER
What your going to have to do is shut the unit down and let it dry up you can't have any moisture inside it. use a enamel base paint any would do just be-careful, where your units paint is comming off is also the units evap coil you don't want to do much sanding. Hope this helps you
Dec 15, 2008 | U-Line Refrigerator Ice Maker
How to remove housing cover in front of ice maker
hi,
here is a picture of your dispenser, i hope it would help you solve your problem.
http://www.partadvantage.com/catalogimage.php/IWZM5EII.gif?geometry(1000x1000)
tnx 4 using fixya,
drcool
Oct 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
59 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
