Make: Sharp Model: LC-42SB48UT turns off and on
The Tv turns off after one minute, turns itself on for one minute then it goes thru the same cycle over and over. Very low hours on TV (less than 300.)
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Posted on Jul 05, 2009
  • 8457 Answers
SOURCE: sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Posted on Aug 17, 2009
  • 57 Answers
SOURCE: Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at www.managemyhome.com right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Posted on Feb 24, 2010
Got no picture but i have sound on my sharp lc-42sb48ut how do i test the t-con board backlight inverter and power supply board?
Normally u have this problem for a while before they just stop showing picture period U can only try unplugging it and try to restart it unfortuneatly this is the problems with LCD TV,s when they play out I know i had one go this way after only 3 years old and cheaper to replace then to try to fix.....#Laborcosts
Nov 03, 2014 | Sharp LC-42SB48UT 42" LCD TV 1920x1080,...
Broken lc-42sb48ut
I would look to see if this unit has a back light and if so it may be your problem--either the actual back light or the voltage source that powers it.
Not likely to be a do it yourself repair.
Apr 29, 2012 | Sharp LC42SB48UT 42 in. LCD TV
Manual for shap 42 lc-42sb48ut
http://www.google.com.ph/url?sa=t&rct=j&q=shap%2042%20lc-42sb48ut%20manual&source=web&cd=2&ved=0CCsQFjAB&url=http%3A%2F%2Ffiles.sharpusa.com%2FDownloads%2FForHome%2FHomeEntertainment%2FLCDTVs%2FManuals%2Ftel_man_LC32SB28UT_42SB48UT.pdf&ei=gnPJToP8EcmgmQX-xbwP&usg=AFQjCNFcndpoltc3KU8SuBqgyCUaLzh0dw&cad=rja
Nov 10, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
I want to connect my Sharp LC-42SB48UT TV to my wireless router so I can access the internet.
Hi, first things first, if you television has a " L.A.N. or W.A.N " port then you are set, it will look like a telephone type " JACK " you need a CAT-5 cable for this. then you should be good to go. Good luck I hope this has helped, Prodzilla
Apr 01, 2011 | Sharp Televison & Video
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
