Question about Troy Bilt 5.5hp Self Propelled Mower
Mower pull cord gets stuck
My pull cord gets stuck and makes a sound like it is hitting metal. my daughter may have damaged the metal housing on it when she was working on a loose wheel today. I cannot see any thing bent and I don't know how to remove the part where the cord winds into. it seem to have rivets holding it on.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Does it get stuck in or out, if it gets stuck out the retractor coil may have broken like the inside of a tape measure.
Posted on Nov 16, 2013
3 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
Posted on May 25, 2009
  • 391 Answers
SOURCE: Pull cord replacement
You don't, you must remove the entire housing to replace rewind parts.
Posted on Jun 01, 2010
Poulan pro lawn mower. not getting fire replaced spark plug still not getting fire
sounds like a coil issue, it is a u shaped multi-layered metal item next to the flywheel when you take off the pull cord housing or a short in the spark plug wire.
Jul 21, 2014 | Garden
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
What is wrong with the toro push mower pull cord if it will not pull out?
I would say check the bolts that hold down the pull cord they are the same thread as the cover bolts but the cover bolts are a tad longer and if used on the pull cord housing they stick down to far and hit the fan blades on the magneto and it will not rotate
Mar 11, 2012 | Toro Lawn Mower With Toro Power Tools
PULL CORD HOUSING IS REVITED TO ENGINE, CAN I DRILL OUT THE RIVETTES AND REPLACE THEM WITH SELF TAPING SCREWS?
You could, but you shouldn't. I assume you need to replace the cord? Remove bolts from the whole sheet metal housing, and remove the cord reel from inside.
Aug 02, 2010 | Craftsman Front Propelled Rear Bag Lawn...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
After my daughter mowed awhile when i went out the pull cord was stuck and i can't start it
The drive shaft probably just needs to be lubricated. When you pull on the pull cord it turns the blade, so if the shaft that the blade is attached to won't turn, the cord won't pull.
If you turn your mower over and look at the shaft that runs up into the mower from the center of the blade, you can squirt some oil up into where the shaft disappears inside the body of the mower. Use a generous amount, and then turn the blade by hand (carefully so you don't cut yourself!) and squirt some more oil. The blade should get easier to turn, and once it's as easy as you think it's going to get, try pulling on the cord and it should pull with no problem.
May 02, 2010 | Poulan Pro " Pro" Self Propelled Mower
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Jul 10, 2009 | Garden
Little metal clamp on my pull string
it is supposed to be there. it keeps the rope from winding all the way into the starter housing.
Jul 09, 2017 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt 5.5hp Self Propelled Mower Logo
115 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
