Question about TP-LINK TD-W8901G Router
Firmware upgrade linksys - TP-LINK TD-W8901G Router
  • 26 Answers
What Linksys router are we talking about?
Posted on Nov 09, 2013
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
I`m use linksys rv042 router I can try firmware upgrade. after firmware upgrade my router`s DIAG light comes on at that point. If I do a power cycle to it, often times, the DIAG light comes on a stays...
sounds like a bad firmware updgrade,
roll back the firmware by redoing the upgrade with your backup that you made prior to the upgrade.
you made a backup right? they may provide older firmwares on the manfactures website linksys is usually good about this.
Jun 11, 2010 | Linksys RV042 VPN Router
Linksys wrt54g firmware
Download firmware file from http://www.linksysbycisco.com/US/en/support for your model and open 192.168.1.1 Leave username blank and in password type admin click on administration and then on firmware upgrade.Browse and select the downloaded file and upgrade the firmware.
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How to Upgrade the Firmware on a Linksys Router
I have update the fireware of linksys router WRT54G ver.2.2 by wireless.. Wrong move.. Then it stop loading.. now I can not get in to the router even i reset the router.. what can i do to have it back..
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
How to upgrade the firmware on a BEFW11S4
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity (wired and wireless) on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have. Make sure to select the correct router version as well, as firmware upgrades frequently vary by version. You can find your router version underneath your router after the model number. For example, ?BEFW11S4 ver. 2?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
TP-LINK TD-W8901G Router Logo
49 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
Robert
Level 1 Expert
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
