Question about Exercise & Fitness
Energetics treadmill reset
Hello, I need to know how to reset the error occured during some test. I got E02 on my treadmill. Is there some kind of console buttons combination which would help me to reset?? many thank. Giacomo
    Top Expert:
  • 12,223 Answers
Reset with the button to the side power button in the down part.
However you can do it usen STOP+enter +speed at the same type.
The indication error if the problem persist indican PCA faulty, RAM memory, or eerprom faulty.
adjust the reed switch, clean it, test for open or faulty, tight and clean the connector very well.
Open the display board and clean all connector from dirty, and corrrosion with contact solver, speciallly the ribbon cable.
God bless youenergetics treadmill reset - 3e2fd085-7a06-4a50-908d-ef603851c3ef.gif
Posted on Jul 11, 2013
SOURCE: Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
Posted on Oct 20, 2009
  • 8 Answers
SOURCE: Carl lewis treadmill
On mine it was the micro switch that senses the rotation speed. The switch is static and placed my a moving magnet usually inset into the drive pulley. The wiring from the sensor could also be faulty.
Posted on Mar 26, 2010
AJIN G
  • 6694 Answers
SOURCE: I recently purchased a Bowflex
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Posted on Dec 27, 2010
SOURCE: console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Posted on Jul 04, 2011
SOURCE: I have a tredmil Energetics power run 3000, when I
Energetics machines are sold by a Swiss company based Woellistrasse 2, CH-3006 Bern, Switzerland
Posted on Aug 22, 2011
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Over speed on Treadmill energetics PR 2.8
please RUN the software calibration for diagnose, troubleshooting, fix it.
read your instr.manual or download from www.fitness.manualsonline.com or www.iconservice.com
God bless you
Jul 18, 2012 | Exercise & Fitness
Hello, I have an ENERGETICS PR 2.8 Power run treadmill which when I press start, counts down then displays and 007 error code. I have checked all the wires down from the display for any damage, any loose...
1) This error code has 2 options
a) Elevation Motor: a) lube the gear and shaft b) adjust the potentiomenter c) test the motor see my personal tips for help.
2) Display board: a) adjust the reed swithc , see the diagram attached, clean, tight the wires connector very well.
After you did the adjustment RUN the software calibration for diagnose and troubleshooting.
God bless you
May 11, 2012 | Exercise & Fitness
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Error 09 checks lower PCA memory locations during the power up test sequence. If a fault is
found during the power up test sequence, error 09 will be displayed. This error code is only used
on products utilizing the dual microprocessor system.
Possible Causes
1. This error message almost always indicates a lower PCA problem when it is consistently
displayed. Failures causing this error message to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the lower PCA
should be replaced. It is possible to see this error message displayed intermittently due to
external causes. If the units A.C. input significantly dips during the power up test sequence
the test could fail resulting in this message being displayed. Treadmills operating on
non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
9.1.0 TREADMILL PRECOR PACE ERROR 3
Dear Sir:
Hello I hope everything is fine.
I will give some Tips:
Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 25, 2011 | Precor 9.21 Treadmill
Searching for authorized repair service for Energetics treadmills in Serbia, Europe (I have Energetics Power Run 2000-HRC, who could fix the electronic?)
if one day you look in my country El Salvador in Central America, here I'll be at your command my mail cardiotech_me@hotmail.com
Mar 05, 2010 | Proform Energetics 2000 Treadmill Walking...
E02 error
E02 indicates that the mode switch did not rotate into the next position after 6 seconds during unloading attempt. This problem can occur for several different reasons, but almost always requires mechanism repair and retiming, a real pro job. Good luck, magic seadog
May 22, 2007 | JVC GR-SXM250 Camcorder
Exercise & Fitness Logo
312 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
