Question about Duplo DF-755 Semi-Auto Paper Folding Machine
Duplo DF 915 grinding noise
My Duplo DF 915 folder makes an intermittent crunchy grinding noise while folding.
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Duplo DF-520 N Manual
late, but...
try this one: http://downloads.udpnet.com/filedb/pafiledb.php?action=file&id=84
Mar 02, 2012 | Duplo Office Equipment & Supplies
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
Jan 19, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I have a PV-DF 2735 TV. The DVD player started making a grinding noise when you try to play dvd.
It seems your DVD get friction with your flat wires ( power and control cables of spinning motor). Just check it out and bend a bit your wires ( while turn off) to avoiding the noise.
Regards,
Dec 24, 2010 | Panasonic Televison & Video
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a duplo DF-520 folding machine. When I turn the unit on and try to do a test fold the word 'OPEN' comes up on the led display. I have the manual and have checked the cover which is closed and the...
I have reviewed your problem and have the fallowing for you to aces.
First, this sounds like a simple open switch problem.
If you are receiving a open cover message, try the fallowing.
Check carefully each of the closing covers or doors.
You should see a tab on the covers that fit into a hole. Beneath the hole is a micro switch. If the tab is not hitting the micro switch, you will receive the message.
Try using the eraser end of a pencil and see if the message disappears.
Hope this solves your problem and you have little to no cost on your repairs.
Happy Holiday's
John
If this works for you, Please Rate Kindly
Dec 08, 2009 | Office Equipment & Supplies
Onan generator making grinding noise while cranking
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Jun 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Message d'erreur sur la Kyocera
Make sure document feeder cable screws are tight and if cable guard (metal bracket) is not installed make sure it is not too close to the wall.
Mar 27, 2008 | Kyocera CS-2550 Black and White Copier
Duplo DF-755 Semi-Auto Paper Folding Machine Logo
199 people viewed this question
Top Duplo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
