Bosch exxcel wwd45
My machine has stopped and allowed us to empty the contents,but is now frozen showing there is 1 minute left on program and the key symbol is flashing. i have tried turning off at mains but no joy
IB4G2008
  • 3587 Answers
SOURCE: helppppppppppp?
aloha..did this get resolved yet?
Posted on Mar 02, 2008
  • 327 Answers
SOURCE: bosch exxcel 1400 express
unplug the device from the mains for few minutes then check out many a times it clears the fault.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Posted on Dec 15, 2008
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
FixinFax
  • 3085 Answers
SOURCE: what does the key symbol mean on the Bosch Exxcel
The door is locked.
Posted on May 30, 2010
Daniel S
  • 4323 Answers
SOURCE: Bosch Exxcel WAE244S0GB machine won't start,
Hi
If the beep sound is coming from the dial not from the bottom where the motor is then the issue seems to be with the Timer/control board going bad and needs to be replaced. However, you can unplug the unit and then blow some air with the help of hair dryer before replacing the Timer motor/control board. If the sound comes from the motor area then it is the motor that has gone bad and should be replaced. When the motor goes bad it will fill with water and empty. One more thing to check will be the door lock-switch assembly, because if the control detects door not locked it won't run cycle and will just drain the water out. Also please let me know the exact key symbol before 0 which is appearing on the panel. Hope this helps... .please post back for further assistance.
Daniel
Posted on Jan 09, 2011
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
Nevers stops...
check your pump is not worn (how old is it)
or
check your brushes
Jan 12, 2014 | Siemens Washing Machines
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
My blackberry 8520 battery drained quickly because it shows busy symbol(clock moving symbol)in each 10-15 second.which programe is it bg?
try to clean your phone log.
1. turn off your gemini
2. take off the batt for 3 minutes.
3. take off the sim card and mmc
4. insert the batt and lets it enter standby mode.
5. press and hold alt key, and press L G L G key, until another menu is open
6. press BB button, and select Clear Log.
7. Restart your phone and enter the sim card.
Nov 27, 2011 | RIM BlackBerry Curve 8520 Smartphone
Hello.. i have a bosch maxx 7 laundry machine... and is showing up the key symbol in the screen... and the machine is not working.. just the light in the screen is on
Hi
The key symbol means the unit is locked. It should be there in the manual. Also try unplugging the machine for 1 minute .It will reset the washing machine.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Washing Machines
Bosch washing machine classix 6 Stopped working. wont let me program it. A key symbol flashes on
I believe that the key symbool indicates that the machine cannot lock the door. Sometimes the result of a slightly sticking door interlock mechanism. Open the door and close it hard and firmly (slam it a bit, but don't get silly about it!). A good test to see if this is the problem is to attempt a program with the door swinging open. If the symptoms (flashing key) are the same, then the issue is almost certainly narrowed down to that door lock mechanism.
If this fails, unplug the machine from the main power source and leave it for 20 minutes to allow it to reset its self, then try again.
Jul 11, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
Hi ive got a Bosch exxcel 1200 exspress washing machine (model num WAE24464GB/03) , the day we moved it worked , when we tried it at new home it wouldnt pump water out . ive cleaned all pipes in &...
Bosch exxcel 1200 exspress washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away
Apr 13, 2011 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
