Question about Sigma SD9 Digital Camera
Sigma SD9 CF card door on camera body broke.
I contacted Sigma repair center and they say parts are no longer made for SD9 since 2011. Not much service from Sigma. Crapy plastic parts. Does anyone know where I can get this part? OR will an SD10 CF door work on my SD9?
3 Suggested Answers
MarkDay
  • 111 Answers
SOURCE: sigma SD9
Sounds like permissions problems. Try using directories under your home directory.. for example if your login is 'jon' try using a directory under /home/jon/ as destination. If it wont let you save there, there are permissions on your home dir which prevent it from doing so.
see also: chmod
Posted on May 22, 2008
  • 83 Answers
SOURCE: Hi, I've got a Sigma SD9 camera that I took to the
Well, while still perfectly usable, SD9 is not exactly a recent model (introduced in 2002), so I can imagine your repairman might have problems locating parts for it.
I would suggest looking for a broken "donor" camera to get the cover from on ebay, craigslist, etc-it might be faster than trying to locate a new part.
Good luck,
Raf
Posted on Nov 13, 2009
Error 99 is my problem... any ideas on a fix?
This may help you, it is from Canon.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Thank you for choosing Canon.
Sincerely,
xxxx
Product Support Representative
Dec 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Hi, I've got a Sigma SD9 camera that I took to the repair shop 3months ago because the battery cover broke. The repairman keeps telling me he cannot locate this part. Is he BSing me or is this part...
Good luck,
Raf
Nov 13, 2009 | Sigma SD9 Digital Camera
Broken screen
can replace at flat rate from panasonic. not economical to repair usually runs around 300 dollars flat rate. parts and labor
Jun 02, 2009 | Panasonic HDC-SD9 Flash Media Camcorder
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
findings.
Please leave for me, a rating...
May 15, 2009 | Canon MF8180C Color Laser MFC Printer
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
Mar 29, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Dec 28, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Sigma SD9 Digital Camera Logo
26 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
